Who's who and what and where...
TTP Engineering my apologises. I made a mistake and I have corrected it.
It was not my intention to mis-inform and be slanderous when I started this thread. We have been in the wI business since the late 80s and there was only Spearco and us. There are no less than (12) makers today. So I thought it would be useful to putting up a list of WIA manufacturers on this site some new WI users can make their own mind up from reading it.
We are not very competitive so you should not see us as a competitor - there were no other ill-conceived motives. If you want me to delete your entry or putting more information on it, just let me know by post.
Richard L
Richard L
Originally Posted by TTP Engineering
Not off to a good start... TTP-Engineering does not sell Snow Performance kits. You did not request this information from us and your misinformation is slanderous. This thread should be deleted if the information cannot be kept factual. We are located in Orlando, FL which is no where near Calardo or Colorado.
Where is the Truth Squad when you need them? LOL
I have updated the alky control, thank your for the post. I leave the Buschure SMC out since Burchure is not a manufacturers. May be we should restart another thread on re-labelled/modified system here?
Richard L
Richard L
Originally Posted by Ultimate CC
Buschur uses SMC and AMS uses alkycontrol
This is a good place to discuss all the technical specificications of the systems listed but would be better if you ask the manufacture to post it themselves, a great deal more accurate - I can normally comment on the principles of the method used. The aquatune system (older version) is way above my head - no help there, sorry.
Richard L
Richard L
Originally Posted by SlowCar
had to dig this one out from a past post, barb fittings and vinyl hose.........any idea how it works?
http://www.aquatune.com/index.asp
I know SMC has a evo spec system who else?
I will add it as soon as I reserach their websites - a job for the coming weeked for me.
Richard
Richard
Originally Posted by Evo_Kid
You should also include this spec
EVO Specific - YES/NO
Yes, I know.
Better run more tests for their special setup specs than offering a system under-tested just to join the crowded WI market. I assure you it will be good when done.
Richard
Richard
Originally Posted by EVO8LTW
Does anyone know what the hold up is at Works? I think they have had an Aquamist based product in the works (groan) forever.
Richard L
Richard L
To ADD what is probably the best feature to a meth system our stage IV upgrade will give you two safeguards against meth injection failure. Here is a video of our system in action. We flipped the meth switch off at 29psi to demonstrate what happens with our stage IV with meth injection.
Don't try this at home...
http://72.41.83.159/video/TTP.Meth.F...Safeguards.wmv
This is what the log looked like right as we turned off the meth power switch at 29psi:
Let me know if you need more corrections. I am sure if readers wants to know more, they will contact via the links provided or read the above post. Things don't just stop after the initial post by me.
I just like to be as brief as possible on the listing otherwise people don't read it properly. I think the "patience" retention time is about 10 seconds on the internet.
Please keep posting, this is a good place to show off your products, thanks to EVOM. Let hope the market will grow to accomdate all of us.
Richard
Richard
We are good, thanks for the corrections.
Richard,
Thanks for starting this thread. I am in the research phase of my WI system. Basically, I want the SAFEST system on the market. Unlike a lot of people with DEEP pockets or sponsers, I can not afford to rebuild/replace a blown engine.
And after a month of research, I am no closer to figuring this out than when I began.
. "The more I know, the more I need to know"
I suggest composing one email and send them fourteen times, or fifteen?
You can start your research here and also encourage the vendors to duscuss their systems here.
These days, people don't make trousers with deep pockets - since no one can afford to use them.
Richard
Richard
