Boost on Alky
Old Mar 20, 2006 | 02:42 PM
silex's Avatar
Boost on Alky
Curious as to what kind of boost you guys are running on alky/meth/h2o injection on 91 or 93 octane. I'm in CA so 91 info would be prime, but I just need numbers. I might need to upgrade my map sensor from the GM 3 bar (28psi) to an AEM 3.5 (31psi) /5 (52psi) bar based on the answer.
Old Mar 20, 2006 | 02:48 PM
fromWRXtoEVO's Avatar
I ru 26psi with 100 denatured alcohol and nozzle #7 on the SMC kit. I had run 28-psi before and I can peak 30psi as well. All this on 91oct
Carlos
Old Mar 20, 2006 | 06:29 PM
Evotech8's Avatar
25-26psi on 100% methanol and Unocal 76 91oct.
Old Mar 21, 2006 | 01:18 PM
silex's Avatar
Well it looks like 30psi is about the max boost people run on an alcohol setup. Can anybody chime in that knows what setups allow for max boost? I also found out the GM 3 Bar allows for 31.1psi so it looks like I'll just stay with it for now until I find a reason to upgrade.
Old Mar 21, 2006 | 01:32 PM
denolloyd's Avatar
I'm running 32psi w/ 100% meth...
Old Mar 21, 2006 | 03:02 PM
Yaroslav's Avatar
i`m going to run 37psi on 93oct w/100%meth 2xM15 nozzles
Old Mar 22, 2006 | 09:40 PM
silex's Avatar
I take you can run that high of a boost due to the stroker kit?
Old Mar 28, 2006 | 10:32 AM
TTP Engineering's Avatar
34.1 is the peak I have logged on stock turbo.
Old Mar 28, 2006 | 11:44 AM
C6C6CH3vo's Avatar
When setup right, it appears that baby's got some *****
What kind of ducting did you use for that psi? What actuator setup?
Old Mar 28, 2006 | 01:18 PM
None, it was on the rollers. Air intake was not an object of attention. This was however WITH MAF sensor on SAFCII + Meth injection and Hallman ProRx Evolution cranked to the max on a Forge WGA equipped with the red spring and some mild preload.
Since, we have moved to MAFTPro with EBC control, changed the Forge WGA to the blue spring (lighter), gone speed density No MAF. Boost control is set to 32.00psi on meth. It takes a certain load on the motor to achieve that boost. Such can be accomplished on a long pull from lower rpm in 4th or 5th gear for example.
Old Mar 28, 2006 | 04:39 PM
400awhp16g's Avatar
Old Apr 7, 2006 | 01:36 PM
808MAUIBUILTEVO's Avatar
i dont know
Old Jun 15, 2006 | 12:55 PM
PANGES's Avatar
Sorry for kinda thread jacking, but i've kinda been searching and have'nt found an answer to my simple question, but I dont think I should start another thread just for my questions... I'm in CA too. Where are you guys picking up your Alky refills? And where are you picking up meth? I've read in another thread that you can get tubs of it from Home Depot. But I'm reading all these alky/meth mixtures, 50/50, 100%.. and all this and I'm confused as hell. I'm trying to take this all in and understand, but I can't seem to get a good grasp on everything. So what percentage is the alky you can pick up from Home Depot? Because from what I understand, there's some meth in the alky there.. I'm seriously considering an alky kit for my IX, but I would like to understand most if not everything that I need to know before I take the step.
TIA guys.
Old Jun 15, 2006 | 06:56 PM
You should be using methanol, not alky for max power.
VP M1 methanol from you local VP Fuels dealer.
Old Jun 15, 2006 | 07:10 PM
Ultimate CC's Avatar
I run between 25 and 30psi depending on % of methanol I am running...
