Dual m10's
Old Dec 3, 2006 | 02:47 PM
  #31
Richard L's Avatar
wrongly posted -- deleted
Old Dec 5, 2006 | 03:43 PM
  #32
Inn-Tune's Avatar
I'm interested in this as well since I'm running a few nozzles off a single sureflo pump with a Coolingmist kit in my daily driver. It's been working fantastic for me for quite a while now, but I haven't measured nozzle pressure or actual flow to see what kind of headroom I have on this pump for expansion.
Old Dec 5, 2006 | 03:46 PM
  #33
coolingmist's Avatar
I can hook up the pump in question to water and video tape it, no big deal. If we get some methanol at the shop in the next few weeks I'll post the same test with methanol as well.
I am 100% confident of my posting with water. methanol does have different properties so I cant confirm until I test it myself.
Old Dec 5, 2006 | 03:56 PM
  #34
SlowCar's Avatar
surface tension of methanol is ~20dyne/cm, density ~0.7g/cc, 0.05cP and water ~70dyne/cm,0.98g/cc, 0.9cP @STP
same pressure, MeOH will have a higher flow rate compared to water thru same orifice
Old Mar 5, 2007 | 10:08 PM
  #35
_EVOlved_'s Avatar
Back from the dead...
How much does the M10 flow in ml/min with the 150 psi Shurflo turned up to 100% pressure?
Old Apr 1, 2007 | 12:25 PM
  #36
SwiftEVO's Avatar
How do you hook 2 jets up to the same pump?
Do you just Tee into the line and tap the intercooler pipe for another jet? How far apart do they need to be?
--Josh
