Any HSF-5 kits installed completely in the engine bay?
Old Jun 26, 2007 | 08:45 PM
SlowCar's Avatar
hi jeff, this is how the meth line goes from back to fromt of car:
Old Jun 26, 2007 | 10:49 PM
2JZfan's Avatar
ok, you guys twisted my arm, I'll put the thing in the trunk... thanks for the info.
Old Jun 26, 2007 | 11:08 PM
SlowCar's Avatar
Old Jun 26, 2007 | 11:40 PM
SlowCar's Avatar
Originally Posted by dudical26
That is interesting, that is a pretty high temp. I bet that is why people have conflicting results when they try to ignite different concentrations of water and meth, perhaps they were not heating it enough.
it is a strong function of the temperature of the bulk liquid volume...the closer it is to the boiling point of methyl alcohol(~65C), the more meoh will distill off and flammable it will be
Old Jun 28, 2007 | 09:26 PM
CO_VR4's Avatar
I was just wondering whether people who are upgrading their fuel systems to a larger S.S. line (like the AMS fuel system) could use their (abandoned) stock hard fuel line to transfer the methanol from the rear of the car forward to the engine compartment. It would need a connector from the Shurflo pump to the hard line, but it would be strong and reliable, and in a safe location.
Any thoughts on why this would not be a reasonable alternative to running a line inside the car?
Old Jul 11, 2007 | 11:57 AM
fixem2's Avatar
TTP, why would running the Meth line under the car be improper? A braided line or a teflon line wrapped in braid should be "proper" under the car. Not sure about you but the thought of having Meth line inside the cabin/door sills bother me.
Old Jul 11, 2007 | 12:03 PM
AlohaEvo's Avatar
that's nice thinking, I might need to take a look at doing that. Right now my line has a braided ss sleeve around it but it wouldnt hurt to get a little more strong and reliable like you said.
Old Jul 11, 2007 | 01:17 PM
TTP Engineering's Avatar
The line should be run from the trunk through the door sill up through the front fender grommet to behind the headlight.
There is no reason to run it outside the car. All you are doing is subjecting it to potential physical damage and if it does get hit out there, you will have an engine failure due to insufficient flow volume.
ISPEVO8
For Sale - Part Outs
Jun 8, 2016 01:29 PM
ryukinevo
Nov 13, 2015 12:00 AM
dsm nexus
Mar 21, 2014 03:44 PM
Hunndy
Nov 19, 2013 02:10 PM
Wick3d3vo9
Feb 27, 2009 08:11 PM
