Sti meth tank
Sti meth tank
I am in the process of buying a meth kit and i was considering different tanks. This pump has a built in pump and low level indicator....i was wondering has anybody ran this tank on their kits? How would the built in pump work with a pump from the actual kit. Also how would i incorporate the low level indicator. thanks
The STi spec C water is a very well built tank BUT it is too shallow
in order not to draw air bubbles into the pump intake and accidentally triggger failsafe from the low level float switch sloshing around from the liquid moving from lateral movements, you will have to keep the 12L tank filled up all the time. A tall and narrow flambeau tank imo is a better tank for this application
Mauricio Evo IV
Jan 11, 2012 08:46 AM
pcamara17
53
Jun 14, 2010 08:46 AM
