Aquamist...Special Thanks!!!
they are, you need to trim off the last 2 bolting tabs to make them fit flush. Check out nicks setup, the lowest 2 R/L tabs have been trimmed off
https://www.evolutionm.net/forums/sh...d.php?t=287268
becareful when trimming - so you dont cut into the tanks
5 quarts work great as direct bolt-on
The 6 quart tanks are the the biggest you would want to go. I am honestly glad I have them because I am injecting so much methanol, when you are getting on it consistently, you go through it all pretty quickly. Like Abner said, you will have to cut the tabs at the bottoms of each tank for a flush fitment to the metal braces in the trunk. Filling the tanks is just as easy as any other setup too, no problems there.
I am going through a suprising amount of meth aswell. I have just one 4 quart tank and two .7mm nozzles (will be changing to two 1.0mm). After a night of messing around I go through about half a tank.
I chose the single 4 quart for less size and weight in the trunk. I don't mind refilling often but other people out there should be aware that a single 4 quart tank with two big nozzles goes fast.
