Nitromethane Thread
Old Aug 8, 2007 | 04:03 PM
bnice01's Avatar
Nitromethane Thread
I want to know who on here has actually tried this, I would like to know:
How long you done it
Did you see any improvement
Any damage
What mix you are running with it
I have research and its still a gray subject on this forum, I ran it once on my srt-4 but I really couldnt do a good comparison. Since when I ran the mix I had a BOV leak from hell and even running open wga I could only boost to 20 but I say the car still felt strong. Anyways just wanted to get some solid info up here for people who are curious and thinking about doing this like myself. I have a mix in my head what I want to use is the 30% Nitro RC Fuel and if your worried abou the oil affecting your nozzle/pump the oil is really @ a low % when mixing it to a gallon of your w/i mix (like 1-3%). If you think about it should increase power quite a bit since nitromethane carries it own oxygen, that why it would result in a leaner mixture but mo powa.
Old Aug 9, 2007 | 10:05 AM
bnice01's Avatar
bump for feed back
Old Aug 9, 2007 | 10:09 AM
dudical26's Avatar
check the aquamist board, there are a couple old threads discussing the use of nitro.
there is not much info on this site about it other than this post which you have already seen.
https://www.evolutionm.net/forums/sh...t=nitromethane
Here is a link to a thread on the aquamist boards
LINK
There is a TON of info on that board.
Old Aug 9, 2007 | 10:12 AM
bnice01's Avatar
Great man thanks for the info
yeah I read all about nitro on that forum couple years ago and recently last week.
again thanks for the feedback
