special tools for aquamist HFS system install
Old Aug 14, 2007 | 07:38 PM
binh's Avatar
Originally Posted by aqmist
Binh, Do you want me to send this stuff to the address you sent in the PM? No need to wait around about the details with this, I can send this stuff prior to leaving on vacation. Just need to get in touch before Thursday night.
Sent you a PM forwarded from Richard. Thanks for your help
Old Aug 14, 2007 | 07:47 PM
binh's Avatar
I also just ordered all these tools for the install.
I will pass them along to whoever needs them for the install for half of what I paid for everything.
Thanks everyone for the guidance!
Old Aug 14, 2007 | 07:51 PM
xiaoni420's Avatar
Damn Binh you just moved up to the wonderful world of methanol injection really quickly!! Haha, This grad school sh*t is killing me!!! 4 more papers to write by Friday! Hope your life is better than mine right now, but by the looks of it, you are doing just fine.
Old Aug 14, 2007 | 08:00 PM
binh's Avatar
Papers? What are those? Haha, I have written one in years especially being an econ major.
I found the aluminum strips where the hardware was. Thanks for the heads up. I ended up spending $50 dollars on bolts, nuts, washers, and alum strips because I was compelled to get all stainless steel for no reason at all. I didn't like how the zinc coated ones felt or looked!
Old Aug 14, 2007 | 08:29 PM
bnice01's Avatar
as usually slow car doing it big, with the great info keep it up bro
Old Aug 14, 2007 | 08:51 PM
Turbo Kyle's Avatar
Good info fellas
Old Aug 14, 2007 | 09:18 PM
xiaoni420's Avatar
Weight savings Aluminum is goood. Haha.
Old Sep 6, 2007 | 08:32 AM
EVO8LTW's Avatar
Originally Posted by SlowCar
8.8mm drill bit, part # = 2958A136 - $6.06
1/8BSP tap, part # = 8328A21 - $15.98
My Vermont American brand 1/8-28 BSP tap says to use with a 5/16" (7.9 mm) drill bit?
http://www.amazon.com/Metric-Pipe-Ta.../dp/B000I1QUU0
Old Sep 6, 2007 | 08:36 AM
SlowCar's Avatar
i think 7.9mm hole is too small...
does the tap look like this or is the tip pointy
Old Sep 6, 2007 | 08:39 AM
SlowCar's Avatar
this drill/tap chart says to use 8.8mm or 11/32" for 1/8 BSP
http://www.newmantools.com/taps/bsp.htm
Old Sep 6, 2007 | 08:41 AM
aqmist's Avatar
In the thread linked below is some helpful info and some additional links that have charts detailing which drill size to use for particular taps.
http://www.srtforums.com/forums/showthread.php?t=318464
Undersized drill is better then oversize but you want to avoid using the tap to not only cut threads but also enlarge the opening........the cut threads get ugly or in some instances the tap will break.
Old Sep 6, 2007 | 09:07 AM
EVO8LTW's Avatar
I have the tap in the link that I posted. It's not pointy. I guess I'll go ahead and use the 11/32nds bit that I already have. Thanks, all.
Old Mar 10, 2008 | 12:48 PM
scheides's Avatar
EvoM Moderator
Anyone have any of these tools lying around they'd be willing to lend out? Specifically, I need the 1/8 BSP tap.
Old Mar 10, 2008 | 02:22 PM
scheides's Avatar
EvoM Moderator
Nevermind, I just ordered a tap from amazon.com.
This thread needed a bump anyways
Old Mar 10, 2008 | 04:47 PM
Richard L's Avatar
With a bit of care, you can use a NPT tap.
Need to test fit every 1/4T or so.
