aquamist system Q
Old Aug 27, 2007 | 01:20 AM
dialate's Avatar
aquamist system Q
so ive got the System 2d http://www.aquamist.co.uk/cp/806-009/806-009.html
and the DDS3 (50mm gauge http://www.aquamist.co.uk/cp/806-425/806-425.html
is this system going to be good, or should i be trying to get the HFS?
mods - 10.5, Forge Actuator, HKS Silent Hi-Power, HKS DP, HKS 02 Housing, Greddy uicp, licp, GSC 264/272, 255 walbro, hks drop in filter, cam gears, Blitz SBC-id, Blitz FattDC, Wideband commander...
Old Aug 27, 2007 | 03:05 AM
Richard L's Avatar
The system is still the best - the fail safe is the most advanced to date. The only drawback is water limitation. without a priming pump, it can only up to 330cc/min.
It will depend on you engine power output and what fluid you will be injecting. For 100% methanol, you need to inject twice as much as water.
Old Aug 27, 2007 | 03:17 AM
dialate's Avatar
im aiming for 235kw on the wheels.. (still stock turbo), might upgrade to a FPGreen at some stage
ive been advised to use a 50/50, meth/water mix?
Old Aug 27, 2007 | 03:26 AM
Richard L's Avatar
If you have already bought the system, invest ion a priming pump relay driver ~$20.00 to boost the flow capacity of the 2d system.
You are very close to the limit of the 2d flow when using 50/50 methanol.
Old Aug 27, 2007 | 04:12 AM
dialate's Avatar
im in South Africa, i got the system from Brandon Leech our local agent, i will ask him for the priming pump relay..
what would your advise on %mix be? i have the DDS3 as well.. i am running a Blitz SBCid would it be possible to connect the failsafe to the Blitz to cut boost in case of failure?
Thanks for you help so far!
Old Aug 27, 2007 | 04:35 AM
Richard L's Avatar
25-50% is good.
Say hello to Brandon for me. There couldn't be that many EVO in SA?
Old Aug 28, 2007 | 12:24 AM
dialate's Avatar
Originally Posted by Richard L
25-50% is good.
nope not too many.. will do.
Old Aug 28, 2007 | 12:25 AM
dialate's Avatar
Old Aug 28, 2007 | 01:33 AM
Richard L's Avatar
As long as the Blitz uses a solenoid valve, the DDS3 can cut boost.
Old Aug 28, 2007 | 01:52 AM
dialate's Avatar
awesome! thx..
