Converting from Snow to Aquamist
I am thinking about converting from the Snow Stg 2 kit to an Aquamist kit. My big question is what is the difference between the HFS-1 and HFS-5. I am on the stock turbo and will be upgrading to the FP Green soon. I have all the other bolt ons. I just want to know what the differences are and do I need the more expensive one of the two.
Thanks.
Thanks.
In a nutshell
The HFS 1 is a single stage unit that basically turns on at a fixed set point. It has a flow sensor, gauge and has built in fail safe. You adjust the flow rate by chosing the jet size.
HFS 5 adds an accumilator so the pump remains at a steady 125 psi and pulses a high speed valve to deliver alcohol in proportion to injector duty cycle in a very linear and smooth manner.
If you buy a HFS 1 you can always upgrade it to a HFS by buying the parts needed to upgrade.
I really like both the kits and have found them both to be highly effective. While the HFS 5 is the superior unit, I have been really excited about the great results and simplistic basic set of of the HFS 1. Bang for the buck its hard to beat all the features of the HFS 1.
Either way they both have the principle advantage of Aquamist - mainly a flow sensor and gauge.
Al
Al
Just out of curiosity: it sounds like the HFS-5 is approaching the operation of a standard no-return-line fuel system (only it delivers water/meth/alky). Is there a reason nobody has looked at using just an off-the-shelf fuel injector for WI and controlling pulse width just like you would for fuel?
Also, it is much easier to install a tiny nozzle in a UCIP than a large fuel injector.
With the fuel injectors you would also have to figure out how to feed it with alky. Injectors are designed to feed from a fuel injector not a thin 4mm line.
Another factor is the contaminant within the fluid. The fuel system is very well filtered but I am not sure if joe public can ensure the filtration and contaminants are kept to a minimum especially non-demin water is sometime mixed in with the injectant.
