aquamist preassembled kits, pictures!
just a note on the preassembled kit that KevinD does..
a breeze to install, except for the hinge mounts of the tank on the frame.. but i guess that requires skill from the user him/her self.. kevinD cannot drill the holes for you... but besides that.. everything was really a breeze, easy to install
Grade A service from KevinD in my book..
thanks man..
thanks man..
PMs sent to those above.
and thanks for the feedback Guz man, because even i have difficulty mounting the hinges i'm working on redesigning a simpler mounting solution (like the pump which is mounted in a minute or so
didnt take pix yet..coz i dropped my car off yesterday to get my GT30R upgrade
but KevinD has a post that shows the tank and pump in the cubby hole area... which i exactly did...
i removed that air filter thing, so the pump would have room to be mounted there, and right above it was the tank, and then routed the rest of the loom under the back seat, diagonally to the passenger side, ran then under the back and front door sills, to the "behind" the glove box area, part of it went through the firewall there, and i zip tied the wires and plastic hose on the strut bar for now, coz i am not gonna let the shop i left the car at to hook it up
and the rest of the wires, 2 of them go to the ECU wires (which i didnt do yet), another long green wire which is for the dimmer light option for the Aquamist gauge...
thats it as of now
i should be picking up my car like this coming tuesday or wednesday, gonna install clutch, head studs, valve springs and retainers, and the aquamist will be last
i just thought of doing the aquamist installation on the car (except for the engine bay) so save some labor time when they hook up the nozzles and do the tuning...
but i will try and take pix once i get the car back and post them here
thats it as of now
suscribed.....i am interested in getting a WI kit, but dont know who to go with. im leaning more towards Aquamist because of friends and EvoM. Did Richard ever get to making a bracket for his kits? Whats the difference between all AM kits? i went on their site and i dont see an HFS-1 or anything like that...they all say System1s or System2d and so forth. Can anyone advise more on this to me? thanks
And KevinD, i like the setup that you made as well....
EDIT: whats the diff between Aquamist and Labonte Motorsports? Pros/Cons?
