To leave on or not to leave on, that is the question...
Old Mar 24, 2008 | 05:41 PM
mrMTB's Avatar
Question To leave on or not to leave on, that is the question...
OK, so I have an HFS-5, and, to be completely honest, I don't go through too much juice on a day to day basis. In fact, there are some days that I probably don't even make it into spray.
So here's my question- should I just turn the DDS3 off until I'm ready to use it? Is there a real difference in component life leaving it on vs. turning if off when I don't think I'll be using it?
And one last question - for those who have the DDS3, does your idle go up when you turn off the unit? Mine jumps to about 12-1300 RPM when I disengage it.
Old Mar 24, 2008 | 08:01 PM
KevinD's Avatar
does it stay at 1200rpm? or does it jump up then come back down?
Old Mar 24, 2008 | 09:09 PM
mrMTB's Avatar
No, it stays at the faster idle when the WI is off.
Old Mar 25, 2008 | 01:42 PM
Evo11V's Avatar
Veteran: Army
+1
who installed it?
Old Mar 26, 2008 | 07:18 AM
Richard L's Avatar
This is unusual. is the +ve supply to the FIA2/DDS3 tapped to the ECU?
Old Mar 26, 2008 | 07:38 AM
hellcat's Avatar
My idle does not change with unit on or off.
Old Mar 26, 2008 | 07:49 AM
KevinD's Avatar
yes the V+ is coming off the ECU supply. hes bringing the car by for fluid change tonight and i'll take a peek at it then.
