Question regarding HFS-1 install
Old Apr 27, 2008 | 09:47 PM
anjapower's Avatar
I installed my HFS-1 kit last night and I believe everything is hooked up correctly. It is spraying at the very least
I am wondering how the boost trigger point is setup - I only wired it to injector, power and ground Where does the boost signal come into play?
Old Apr 28, 2008 | 11:35 AM
scheides's Avatar
EvoM Moderator
You use one trigger or the other. When you have it setup to trigger via IDC, you do not use the boost one, and vice-versa. Just use the IDC trigger, it is best!
Old Apr 28, 2008 | 11:57 AM
anjapower's Avatar
Gotcha. What do you recommend as a trigger point IDC wise? I will be running 50/50 methanol on a full bolton stock turbo, probably the .9mm jet.
Old May 2, 2008 | 10:36 AM
anjapower's Avatar
bump - any suggestions on trigger point?
Old Jul 7, 2008 | 09:30 AM
Boricua_Evo's Avatar
Did you get this resolved? Post if you did, it'll help us al out. Thanks
