Alky with low compression
Old May 18, 2008 | 12:58 PM
4G63 T's Avatar
Guys,
i'd like to know how many alky users have low cylinder compression.
Old May 18, 2008 | 09:45 PM
codean's Avatar
due to what reason?
Water/alcohol injection, when used and tuned properly, will not cause noticeable accelerated wear of engine parts.
Old May 19, 2008 | 04:57 AM
4G63 T's Avatar
Originally Posted by codean
due to what reason?
Its hard to speculate, it might be co incidental but 3 evos with alky has this problem. 2 i know for weekend use.
Old May 19, 2008 | 10:19 AM
codean's Avatar
Yeah, there could be a hundred reasons why this is. What kits are they using and who is the tuner?
How many miles do they have on them now vs when the kits were installed?
Old May 19, 2008 | 04:17 PM
esevo's Avatar
I had low compression... I doubt caused by the WI rather, the effects from it AKA more BOOST. I just did the drop in pistons to find the factory cylinder 4 piston had a cracked ringland. I think the factory internals can only take so much for so long! In this case 2 years of 28 psi plus!
Old May 19, 2008 | 09:27 PM
4G63 T's Avatar
bump
