to soon for meth?
Old Jun 23, 2008 | 01:42 AM
NJ_EveOhVIII's Avatar
to soon for meth?
i just picked up my evo VIII and shes completely stock...looking into getting hks rs intake, BOV (still up in tha air with this one), TB , EBC...thats pretty much it for a few months i already have the meth kit from by previous car am i going to see much gains with these minor mods? should i get it all tuned at once or the mods then the meth kit? what kind of boost am i looking to put out?
Old Nov 9, 2008 | 11:33 PM
SloEvo8's Avatar
You should save the meth for when you get your other support mods on. After you get those mods, then you will need a tune anyway for the meth.
Old Nov 10, 2008 | 02:10 PM
RunRunRun's Avatar
If you have everything, I would put on the mods then get your shop to put on and tune the meth all at the same time. As for the BOV, get the JDM MR. For 120 bucks it should be good at your boost level. With the meth you will probably do around 28 psi.
Old Nov 10, 2008 | 02:19 PM
TxEvo8's Avatar
I just replaced my JDM MR DV because it would not hold 30 lbs, 27 was the most that I could get out of it. I went with the Forge RS.
Lancerguy'03's Avatar
the JDM MR BOV will not work to well at anything above 24psi....it will start to leak....so if your going to do meth and run high boost you need a better BOV. like APS TwinVent or TIAL or the other real popular one that i cant think of the name for...but it has a RS in it...
Old Nov 10, 2008 | 02:20 PM
wow Jim.....nice timing.....yeah the Forge RS...
Old Nov 10, 2008 | 02:22 PM
RunRunRun's Avatar
Alright so don't do the JDM MR BOV haha
Old Nov 10, 2008 | 02:24 PM
TxEvo8's Avatar
Just speaking from experience here in north Texas...
Old Nov 10, 2008 | 02:27 PM
RunRunRun's Avatar
No that's fine, I wasn't being sarcastic or anything, I'm only running 24psi so I wouldn't know. Good input
Old Nov 11, 2008 | 09:29 AM
dsmbruno's Avatar
For those mods I wouldnt really do meth. Its basically a stock evo with an intake and exhaust, so running 27-29 psi is probably not the smartest idea. I would do cams, injectors and fuel pump with the meth kit. But even then, your stock intercooler would be heat soaked very quickly with high boost. Also, with high boost many people will start mentioning head studs. As far as BOV, my jdm mr has seen 27psi with no leaks. It can be crushed to hold 30+ psi. PM me if you have any questions...
EDIT: nvmd... this thread is from june
Old Nov 11, 2008 | 02:22 PM
krazy4's Avatar
Meth will always help keep the temps down and keep detonation to a minimum.
I say do it.
Do this too.
Old Mar 15, 2009 | 07:07 PM
X91EVO's Avatar
Registered User
safest way is race fuel.. buy a high end meth kit to keep it safe
