what devices can be used to switch between maps?
i am debating on getting a meth kit, but i will mostly run pump gas. what can i use to easily swap betwewn the two?
correct thats what i want pump gas on one setting and pump plus meth on the other with the flick of a switch
unless you have a wastegate solenoid trigger to cut boost to wastegate pressure when your meth kit is off and just have your car be slower than a mini van
there is more to it than that...not only do you need your meth set up on a switch but you need to be able to control your boost and ecu settings also
I just noticed you live in central FL. Maybe try contacting TTP? They have been doing the "kill switch" thing for awhile now with good success. Just a flip of a switch and you switch between a non meth map that also cuts power to the meth pump, and your meth map and powered meth pump. Good luck!
https://www.evolutionm.net/forums/sh...d.php?t=351292
with the GM BCS you can run boost aound ~21psi on wastegate, Jackoftrades has developed a wire harness for map switching, and with the help of Tephra's ALTMAP you can set the meth kit to run how you want it... heres a vid of tephra+GM+Aquamist meth kit:
https://www.evolutionm.net/forums/sh...d.php?t=334574
Use the stock ECU with the map switching patch. Some meth kits can be incorporated to automatically switch to the safer maps (Aquamist,AEM and a few others so far) if there is a failsafe triggered. Also, you can incorporate your Zeitronix WB's alarm output feature to trigger the safer maps at the same time for double the safety. For pennies you can have more protection than you can imagine.
You can also have a manual bypass so you can shut off the alky kit completely and run on your "pump gas" tune only. The AEM kit uses the same bypass switch with the alt-map harness to turn on/off the alky kit while at the same time switching between the respective maps all at once. The Aquamist harness is set up so if you turn the Alky kit off with the on/off button on the monitoring gauge, it switches maps as well.
