Upgrades to Kits and Components in ALL Snow Performance Systems!
Old Jul 31, 2008 | 03:19 PM
Ultimate CC's Avatar
In an ongoing pursuit to constantly improve the quality and function of our systems, Snow Performance has upgraded a large number of aspects of the kits.
Fittings: All Snow Performance fittings are custom made. These are all metal, full nickel-plated (including the quick-release collars)and EPDM seals for 100% methanol-proof useage.
Boost Hose: This has been upgraded from high-grade Tygon tubing to Silicone hose that can withstand 100psi!
Solenoid Valves: Again, these are custom manufactured just for Snow Performance. Larger ports for better flow and no pressure drop, even with 3 large nozzles. Large diameter, EPDM seal with a powerful coil (motor) to drive the seal positively closed or open.
Level Switches: New design level switches are smaller, higher quality and easier to install. Simply drill a hole, install the EPDM seal, and insert the float switch.
Fluid Tubing: Snow Performance has always had the highest quality fluid tubing available, with 400psi working pressure and 1200psi burst pressure ratings. Now, this same tubing is made custom with our name on it.
Snow Performance will always strive to produce the best-performing and easiest to use systems available. Watch this thread for more updates!
Old Aug 1, 2008 | 10:21 AM
Boricua_Evo's Avatar
That's sweet looking!
Old Aug 1, 2008 | 02:10 PM
yea they are great...
Old Aug 3, 2008 | 12:32 AM
daisaw1219's Avatar
do all kits come with the solenoid to prevent drip or siphoning of the fluid
Old Aug 3, 2008 | 12:45 AM
daisaw1219's Avatar
plus do you have wire diagram for the new safe injection. it is not on the site. I just want to know if it could feed a 5v signal in case of malfunction or no flow.
