Boost leak test with meth kit?
Old Aug 1, 2008 | 08:55 PM
BCOZEVO's Avatar
Quick question, if I do a boost leak test with my meth line hooked up on the UICP with the pressure from the test will air push back into the tank? Or does the pump stop that from happening?
What is the recommended way to boost leak test with a meth kit installed?
Old Aug 2, 2008 | 03:35 PM
BCOZEVO's Avatar
Anyone? Its a boost leak test I am sure you guys do them all the time..
I am waiting to test my car based on the post.
thx
Old Aug 2, 2008 | 10:01 PM
cpoevo's Avatar
Pull the nozzle and put in a 1/8 npt plug from Home depot to do the test.
If you have a solenoid you dont need to plug anything just do the test.
Old Aug 3, 2008 | 12:15 AM
ddillard424's Avatar
or just pull the power to the pump...
Old Aug 10, 2008 | 10:10 AM
Evoryder's Avatar
..ok
THe pumps have built in check valves + you should have a solenoid valve in addition. No need to disconnect fitting, if you are worried just get do the home depot 1/8npt plug recommendation
safat_evo
Sep 19, 2016 02:12 PM
BrownSuga
May 20, 2016 01:36 PM
tim85851
31
Oct 12, 2011 02:51 PM
EVOIXreno
Jul 25, 2011 07:57 PM
blackonblackevo
30
Jul 5, 2007 05:18 AM
