Direct port meth injection
Old Aug 14, 2008 | 06:06 PM
jmtx86's Avatar
Im looking to put a jet in 6" from the TB and a jet in each intake runner. Im looking for a good kit to support this setup. I would like to have something similar to aquamist's kit which taps the injector harness to make sure you done "flood" the motor with meth.
What size jets should I use in the intake manifold and what size should I use in the intake runners?
Im looking to safely support 500 whp on the stock block at around 27-30 psi.
-John
Old Aug 14, 2008 | 06:10 PM
jmtx86's Avatar
PS if anyone is interested in a trade I have a nitrous express kit with bottle warmer kit (pressure senors on/off, gauge) purge, fuel and nitrous solenoids. It would include all lines needed to install but no wiring.
Just food for thought.
Old Aug 19, 2008 | 08:48 AM
Devilsown's Avatar
I am not a big fan of direct port injection. Usually the same cooling gains can be had by going the simple route and only running 1 nozzle. Or 2 if running dual intake tracks.
ON a s4 i would recommend going with a total of 7-8gph of nozzle size.
If wanting to do a multi port i would run 1gph on each cylinder and 2gph on the intake.
