AEM Meth + IFS-10 + Map Switching?
Old Aug 25, 2008 | 03:46 PM
rish197's Avatar
Hi,
Wondering if anyone that is running the AEM kit also has the Labonte IFS-10 Failsafe and map switching with the Jack_of_Trades cable? My problem is the instructions of the IFS-10 says to wire black to ground and red to pump +. That wiring will keep the failsafe active until the flow is past the trigger point. With the map switching, when it detects a failure, it shuts the meth off, and puts me in "low" boost. This way, the meth never flows b/c it detects a failure.
It seems to be an endless loop. Any ideas how I can wire the IFS-10 failsafe to check for flow AFTER the pump fires?
Thank You!
Jason
Old Aug 26, 2008 | 05:37 PM
rish197's Avatar
Is there anyone running the AEM kit + IFS-10?
Old Aug 31, 2008 | 06:25 PM
wesside's Avatar
Honeslty I don't know of many ppl that are using aem kits and there is alot of ppl using the tephra patch but I'd say mostly running aquamist kits like myself
