tubing for meth?
Old Aug 28, 2008 | 08:30 PM
lemmonhead's Avatar
tubing for meth?
I got a labonte injection kit but the provided tubing was short. The only thing I found was milky polythene tubing. the store lable says its good for 150PSI and 70 Degrees F. If I heat wrap protect the tubing in the engine bay would the tubing be ok to use?
Dan @ Labonte if you guys read this as a sugestion please provide 2-3ft more tubing in your kits.
Old Aug 31, 2008 | 09:27 AM
EvoJoeIX's Avatar
contact 4ws, he can get you some tubing most likely
Old Sep 15, 2008 | 05:59 PM
k2boarder3187's Avatar
Everyones is short if you mount it in the Trunk..its b.s for the price a lil more tubing should be provided to prevent down time and hold up.
Old Sep 15, 2008 | 11:17 PM
Asmodeus6's Avatar
You can order more tubing 5/10/15ft when you order the kit.
