What is the best Pre-Mixed WasherFluid to use for meth injection?
Old Jan 13, 2009 | 06:39 PM
meat_EVO's Avatar
I just installed my Water/Meth kit in the evo and want to see what everyone else was running, and found the best results with.
I bought Peake....
Has anyone found that any certin brands have a more exact mix?
Old Jan 13, 2009 | 07:39 PM
lemmonhead's Avatar
do a search for my thread on why you shouldn't use windsheild wiper fluid.
Old Jan 13, 2009 | 08:15 PM
chaotichoax's Avatar
most people use straight meth or de-naturalized alcohol
Old Jan 16, 2009 | 11:19 PM
KeithD's Avatar
I am running Heet and Distilled water. It is a 50/50 mix and I have not had any problems. There is no benefit to running straight alki, you need the water. As for using windshield washer fluid, well the problem is that they are not always accurate with how much alcohol is in them. Sometimes you will get the right mix and the next time you buy a bottle you will get something different, even with the same manufacture. They don't worry so much about it because the only reason there is alcohol in washer fluid is to keep it from freezing. Hope this was a help.
Old Jan 18, 2009 | 02:36 PM
evo082006's Avatar
Heet (yellow bottle) and distilled water. Please don't use washer fluid. I used denatured alcohol for a while, but got a little more from the heet
