instead of denaturated alcohol
Old May 11, 2009 | 07:08 AM
koullis's Avatar
hi, sorry if this has been posted again. i just need some answers.
in my country, cyprus, i can not find either methanol or denaturated alcohol.
so, the question is: can i use 90% pure alcohol? i will use it 50-50 with water.
Old May 12, 2009 | 07:07 AM
koullis's Avatar
bump...
Old Jul 21, 2009 | 04:53 AM
burgers22's Avatar
It would depand on what the other 10% is.
I run De-natured alcohol, commonly known as Mythalated Spirits and run it 50/50, its 90% ethanol, 9.5% wood naphtha and 0.5% of pyridine.
Sounds similar in % terms as your stuff. See if you can find the ingredients.
MB
Old Jul 25, 2009 | 01:20 PM
coastevo's Avatar
You could consider distilling your own ethanol and running 95-100 precent E? I'm planning on building a still for this exact purpose and buying corn feedstock to make E95 (or 100 if I use a molecular sieve to filter the extra water in the blend) for about 50cents to a dollar a gallon. If you live close enough to a saw mill you can take the saw dust off em and make ethanol from wood as well by using a relativley simple process described here: http://www.green-trust.org/sawdust_ethanol.htm
In this case if you could get free sawdust from the mill you could drive your car for maybe 10 or 20 cents a galllon after that initial startup investment in building your fermenting containers/still and buying the enzymes(which if done smart could be quite cheap by raiding your local junkyard or garbage lot).
This is also legal in the states (not sure about most other countries) if you apply for a free permit from the Bureau of Alcohol, Tobacco & Firearms, but if you go the legal route in the states you will have to distill outside, have the possibility of them coming by and inspecting your operation, and also using some kind of additive to keep the alcohol from being "beverage grade"; usually by just adding some regular fuel(the ethanol must be water free to do this or the gasoline can seperate from the rest) or a small amount of methanol (no concern with some water in the mix).
Also it should be noted that going the legal route can make you elligable for some tax rebates for driving an ethanol car or even for selling ethanol fuel.
Plus I want an Evo that runs on sawdust, don't you!
Old Jul 25, 2009 | 01:25 PM
Bobster22388's Avatar
You could also use washer fluid concentrate and mix it with water. I know a couple people that use that in place of methanol because it's a lot easier to find.
Old Jul 26, 2009 | 03:16 PM
coastevo's Avatar
I've heard there ca be unwanted additives and dyes in washer fluid and that it's also important not to get the one that works in 30 degree and under weather cause it has antifreeze in it
Old Jul 26, 2009 | 11:54 PM
burgers22's Avatar
That rather depands on what the anti freezing agent is, if it's ethanol or methanol then it's a good thing. Do look at the ingredients though, and give it a shake, if it stays frothy then it may have detergents in it and those should be avoided.
MB
scheides
13
Dec 20, 2010 07:26 PM
DCsleeper
Oct 13, 2007 04:32 PM
fromWRXtoEVO
Dec 17, 2005 06:19 AM
AutoEuphoria
Apr 6, 2005 06:02 AM
EvoTech
88
Mar 3, 2005 07:45 AM
