help with aquamist HFS-1
Old Sep 11, 2009 | 08:08 AM
2BARevo's Avatar
having issues with my setup. boost enabled led and water level sensor led are blinking back and forth when throttle is applied. tank is not empty. cant see any leaks. any one know what this could possibly mean. setup was installed and setup by a local tuner. any help is greatly appreciated.
chris
Old Sep 19, 2009 | 11:28 AM
Richard L's Avatar
Chris,
Better late than never, sorry I missed this post. Please tell me which version of HFS-1 do you have?
Old Sep 23, 2009 | 10:36 AM
2BARevo's Avatar
hsf1 V8
Old Sep 23, 2009 | 11:33 AM
Richard L's Avatar
Two possible causes:
1) water tank level senor is cable is seeing a short circuit. Unplug the water level sensor and let me know if it stops the yellow led coming on. If it persisted, look for a short circuit on the cable.
2) If the B led blinks, it means there is a fault with flow after the system is triggered or the water level sensor is shorting out.
3) Check if the water level sensor is pointing up with a full tank.
Old Sep 23, 2009 | 07:39 PM
2BARevo's Avatar
thanks ill check them out.
