Labonte Meth Inj Solenoid Testing Video
Old Sep 25, 2009 | 12:33 PM
Labonte MotorSports's Avatar
We did a quick video to show you why all Labonte Water/Methanol Injection system come standard with a Fluid Control Solenoid - INSTANT RESPONSE RATE. While other systems have nothing or check valves, without a solenoid you are still going to get fluid drip and puddling in your intake. Once the pump signal stops all the line pressure will bleed out into your intake without a solenoid. A check valve will still bleed fluid until pressure drops below the opening pressure.
The video also shows that a solenoid placed too far away from the nozzle will have no effect. We did this test as some have posted install photos of the solenoid located in the trunk by the pump as recommended by the "experts" - bad idea.
Our entire line of VC series methanol injection controllers have also been updated with a second +12V output channel designed to control a solenoid or NOS relay. This simplifies install wiring and no need to tie in solenoid to Pump PWM wire resulting is instant response rate from the system.
http://www.youtube.com/watch?v=UQx3pT6TgiM
Old Sep 25, 2009 | 06:18 PM
tephra's Avatar
nice work.
i would have thought putting the solenoid as close to the jets was ideal... not sure why anyone would recommend different.
I noticed that your solenoid is LOWER than the jet, if you ran the same test but with the other way around would it drip?
ps your second paragraph is wrong (typo i am sure)
Old Sep 28, 2009 | 12:54 PM
Tanks, corrected type.
With short distance to the nozzle the solenoid can be higher with no issues. Will be doing update to video soon to add check valve and show results. Will redo with solenoid higher.
Richard L
149
Feb 27, 2016 03:01 PM
4WS Tuning
116
Oct 21, 2011 03:08 AM
Labonte MotorSports
55
Aug 25, 2011 01:05 PM
cij911
Nov 16, 2010 12:38 PM
4WS Tuning
29
Jul 16, 2008 10:34 PM
