e85 injection instead of alky and a 50/50 mix
Hey I'm at work and I just started thinking can you run e85 in instead of akly/h20 mix ?if you can wat would be the currect afr in boost?? Also does it seem to make sence to even do this? I currently don't run a alky set up but I have a creative mind...lol.thnx inadvance.
I ran E98 through my aquamist kit spring 2008 and it worked ok, but according to richard@aquamist the gasoline is *very* rough on the motor seals so with E85 it'd be worse. Good idea, though
(on the flip side, the pump is alive and kicking today, but with 50/50 meth/water
that was not a bad idea at all only thing is you would want the 5 gal resovior and not any of the smaller ones sold with most kits because of how much more fuel e85 uses.
