Low Flow
Old Oct 6, 2010 | 03:54 PM
Richard L's Avatar
I looked at the spray video, the water seemed to flow back into the tube, can you explain why this was happening. Theremight be a possible leak at the flow sensor? Perhaps there is a small leak an dcaused the low flow reading?.
Old Oct 6, 2010 | 04:12 PM
EvoVIII808's Avatar
I just check all my hoses, and there is a leak Leaking from the Flow Sensor on both sides, and the Solenoid Valve on the 4mm side. Anyway to fix these problems, or do i need to replace these units?
Old Oct 7, 2010 | 01:19 AM
Richard L's Avatar
You don't have to replace the sensor but the two push-in fittings. We have now replaced them with compression types (806-393). They are available at howertonenginering .See picture below:
http://www.howertonengineering.com/options_access.html
Old Oct 7, 2010 | 11:23 PM
EvoVIII808's Avatar
Alright, about to order 3. thanks
legacyGSR
Nov 26, 2016 05:16 PM
3bar_dc2
Sep 24, 2015 09:16 AM
ekizenbe
Nov 21, 2010 03:49 PM
burnzy
14
May 2, 2009 01:09 AM
fred 62
15
Nov 15, 2007 04:56 AM
