HFS5+Tephra Map Switching+MAC valve+MBC
Old Feb 25, 2013 | 07:23 AM
EvoPower81's Avatar
Hey guys I finally got around to setting up my alt maps where I used the following setup - http://www.aquamist.co.uk/forum/gall...HFS-5-EVO9.gif
However, I am having some issues where my voltage output to the pin 24 of the ecu. I did not use the jamie harness however im using a 10k 1/4w resistor. I am getting 12volts on this wire which is perfect for the MAc valve but dangerous for the ecu. I understand it suppose to be >5volts. Any help would be appreciated!!
Old Feb 25, 2013 | 06:12 PM
EvoPower81's Avatar
Thought this would have been an easy fix for one of the gurus . No suggestions?
Old Feb 25, 2013 | 08:29 PM
gear head's Avatar
Which version of the DDS3 are you using?
Old Feb 26, 2013 | 03:37 AM
EvoPower81's Avatar
Originally Posted by gear head
which version of the dds3 are you using?
v9
Old Feb 26, 2013 | 05:31 AM
gear head's Avatar
Bummer, DDS3 V10 has a 5v output.
You will need to make or buy an Altmap harnesss. My suggestion would be to use ecu boost to drop boost and forget the mbc/Mac valve combo.
Old Feb 26, 2013 | 12:23 PM
EvoPower81's Avatar
I have tried ecu boost control before and I just dont like it. I prefer the simple stuff. Once I know the Altmap harness will work I just buy one. Cheaper than upgrading to v10 anyways..
Old Apr 3, 2013 | 05:01 AM
EvoPower81's Avatar
Back at this again yes!!! I have made my own harness and now I get 4.8v going to the ecu pin. My ICS light flashes when I turn on my aquamist gauge to show Im in the alt map mode however when I do logs it still shows that its using the Main Maps. Anyone had this issue before? I figure it has to be switching since the ICS light flashes ..Settings:
Alternate map Time to Active = 500ms
" " Load Threshold = 110 load
" " ADC0F Threshold = 3.02 volts
Enable Alternate Map Master = ADC0F = 1
Old Apr 3, 2013 | 09:10 AM
EvoPower81's Avatar
Common... someone has had this problem before?
Old Apr 5, 2013 | 10:32 AM
EvoPower81's Avatar
Old Jun 1, 2014 | 07:21 AM
blacktab420's Avatar
Did you ever figure this out ?
Old Jun 2, 2014 | 04:12 AM
EvoPower81's Avatar
Yes I was using the wrong ROM for my ecu. I use the 90556701 SD rom and it works fine!
Old Jun 2, 2014 | 08:07 PM
ok thanks !
blacktab420
Feb 2, 2016 09:51 AM
Evo11V
Jan 16, 2015 10:16 AM
zagorych
Aug 7, 2014 01:42 PM
Richard L
Feb 26, 2012 01:59 AM
lapulapu
Sep 9, 2008 05:52 PM
