-   Water / Methanol Injection / Nitrous Oxide (https://www.evolutionm.net/forums/water-methanol-injection-nitrous-oxide-173/)
-   -   what's the best jet to spray meth???? (https://www.evolutionm.net/forums/water-methanol-injection-nitrous-oxide/279579-whats-best-jet-spray-meth.html)
EvoDan2004 Jun 26, 2007 06:03 AM
Hey all. Ok I got meth injecton. Coolingmist meth kit.. I'm going for 500hp.. ( yes bigger turbo) What I'm wondering is what is the best jet to spray meth and what size is recommended.. I know all different jets spray a different patern and what not. What one is the best and why?? Plus again what size will I need.... thanks for the help
dudical26 Jun 26, 2007 06:22 AM
How big are your injectors?
What duty cycle do you typically see throughout your rev range?
Are you going to run 100% meth, water, etc...?
BoostN Jun 26, 2007 06:27 AM
Coolingmist will tell you what is best for your application. Just give em a call.
EvoDan2004 Jun 26, 2007 07:38 AM
Oops my bad..
100% meth
1000cc RC injectors
Stock ecu
Duty sycle I don't know because I'm building the car up now. It will have a 3076 or like tubro on it... going for 500hp around that ballpark..
EvoDan2004 Jun 26, 2007 07:52 AM
Ok that's cooling mists recommendation... many companys make many kinda of jets. Big small and with different spray paterns. My question is what spray patern is best and what company makes it.. And what size do I need.
dudical26 Jun 26, 2007 10:01 AM
I think every company provide jets that have a cone shaped spray pattern. Some might have a wider angle cone but I think most companies provide fairly similar jets. Your best bet is to use Coolingmist jets as they will probably hook up to your system easily.
SlowCar Jun 26, 2007 11:54 AM
use 2 smaller jets spaced apart than 1 big one. distribution and better atomization can be achieved
EvoDan2004 Jun 26, 2007 05:43 PM
where do you recommend putting each jet?? i was thinking insted of putting it on the uicp can we tap it into the top of the intake manifold???
what size jets do we use for a dual spray 500hp car??
SlowCar Jun 26, 2007 11:28 PM
space the meth injectors ~intake manifold width apart.
as to jet size for high powered/boost evo, scott@ttp or 94awdcoupe are the gurus at that
EvoDan2004 Jun 27, 2007 02:11 AM
Ok so put on at the bend on the uicp like spraying into the t/b and the other about 1 foot down from the top jet into the mid piont of the uicp??? Thanks man
EvoDan2004 Jun 27, 2007 06:58 AM
Also I recerc my bov. Not sure if it matters but should I put the second jet befor or after where the bov tube meets the uicp
EvoDan2004 Jun 27, 2007 06:53 PM
bump for more info?
EvoDan2004 Jun 28, 2007 04:19 AM
Bump
EvoDan2004 Jun 29, 2007 03:58 AM
Bump
