what's the best jet to spray meth????
Old Jun 26, 2007 | 06:03 AM
EvoDan2004's Avatar
Hey all. Ok I got meth injecton. Coolingmist meth kit.. I'm going for 500hp.. ( yes bigger turbo) What I'm wondering is what is the best jet to spray meth and what size is recommended.. I know all different jets spray a different patern and what not. What one is the best and why?? Plus again what size will I need.... thanks for the help
Old Jun 26, 2007 | 06:22 AM
dudical26's Avatar
How big are your injectors?
What duty cycle do you typically see throughout your rev range?
Are you going to run 100% meth, water, etc...?
Old Jun 26, 2007 | 06:27 AM
BoostN's Avatar
Coolingmist will tell you what is best for your application. Just give em a call.
Old Jun 26, 2007 | 07:38 AM
EvoDan2004's Avatar
Oops my bad..
100% meth
1000cc RC injectors
Stock ecu
Duty sycle I don't know because I'm building the car up now. It will have a 3076 or like tubro on it... going for 500hp around that ballpark..
Old Jun 26, 2007 | 07:52 AM
EvoDan2004's Avatar
Ok that's cooling mists recommendation... many companys make many kinda of jets. Big small and with different spray paterns. My question is what spray patern is best and what company makes it.. And what size do I need.
Old Jun 26, 2007 | 10:01 AM
dudical26's Avatar
I think every company provide jets that have a cone shaped spray pattern. Some might have a wider angle cone but I think most companies provide fairly similar jets. Your best bet is to use Coolingmist jets as they will probably hook up to your system easily.
Old Jun 26, 2007 | 11:54 AM
SlowCar's Avatar
use 2 smaller jets spaced apart than 1 big one. distribution and better atomization can be achieved
Old Jun 26, 2007 | 05:43 PM
EvoDan2004's Avatar
where do you recommend putting each jet?? i was thinking insted of putting it on the uicp can we tap it into the top of the intake manifold???
what size jets do we use for a dual spray 500hp car??
Old Jun 26, 2007 | 11:28 PM
SlowCar's Avatar
space the meth injectors ~intake manifold width apart.
as to jet size for high powered/boost evo, scott@ttp or 94awdcoupe are the gurus at that
Old Jun 27, 2007 | 02:11 AM
EvoDan2004's Avatar
Ok so put on at the bend on the uicp like spraying into the t/b and the other about 1 foot down from the top jet into the mid piont of the uicp??? Thanks man
Old Jun 27, 2007 | 06:58 AM
EvoDan2004's Avatar
Also I recerc my bov. Not sure if it matters but should I put the second jet befor or after where the bov tube meets the uicp
Old Jun 27, 2007 | 06:53 PM
EvoDan2004's Avatar
bump for more info?
Old Jun 28, 2007 | 04:19 AM
EvoDan2004's Avatar
Bump
Old Jun 29, 2007 | 03:58 AM
EvoDan2004's Avatar
Bump
EvoJoeIX
Jul 1, 2008 01:21 PM
bnice01
Jun 5, 2008 07:58 AM
Mirage2.0
11
Mar 16, 2008 06:50 PM
Pure Playaer
Jan 3, 2008 09:17 PM
EVO8LTW
43
Jan 16, 2007 01:47 PM
