question about aquamist hfs-1 install
i got my kit and have started my install,not so bad ..just a few things id like to ask
ive read the instruction manual a few times now and lots of posts . :o ....... 2. i have a greddy profecb bc is there a way i can take a signal from that and hook it to the v8 junction box?(im confused from whay ive read is it just the ground taken from it selonid to the junction box?) 3.the red wire from the 12v-in that goes to the fuel injector on the ecu anyone ?i saw u have diagram of the 05 ecu, 4.the green trigger wire does that go on injector also on the ecu ? the start.. will post pics of my install has i get it in :beer: http://i148.photobucket.com/albums/s...h_DSC00467.jpg http://i148.photobucket.com/albums/s...h_DSC00465.jpg http://i148.photobucket.com/albums/s...h_DSC00464.jpg http://i148.photobucket.com/albums/s...h_DSC00463.jpg http://i148.photobucket.com/albums/s...h_DSC00462.jpg http://i148.photobucket.com/albums/s...h_DSC00470.jpg http://i148.photobucket.com/albums/s...h_DSC00473.jpg http://i148.photobucket.com/albums/s...h_DSC00475.jpg http://i148.photobucket.com/albums/s...h_DSC00481.jpg |
bump..rich,ab,jack?anybody?
1 - the line will run any water-methanol mixture
2 - i have not installed a ebc before...but with it off, you should run WG boost. i think the solution is splitting one of the wire going to the ebc solenoid and connecting it between pin 11/12 on the dds3v8 board. Someone might want to confirm this 3 - pin #59 on the ecu 4- green trigger wire goes to pin #2 on the ecu thanks to ttp for the ecu pinout http://www.ttp-engineering.com/TTP.IX.ecu.pdf |
thank you very much slowcar.and ttp for the diagram:)
if i have a standalone ecu i can run 11,12 to it for map switching ?
slowcar
you have redwire with the fues from the v8 #23 +12v-in to the ecu #59???i looked on the diagram of the ecu and it didnt show 59??? and the trigger thats ran to the #2 fuel injector 1 or it dont matter? im all installed and ready to spay some water for a test but i just dont have it tapped to the ecu yet i just wanna be 100% sure..;) anyone else who has info with wireing please comment. |
Originally Posted by pbevo12
(Post 4679320)
slowcar
you have redwire with the fues from the v8 #23 +12v-in to the ecu #59???i looked on the diagram of the ecu and it didnt show 59??? |
cool thank you evo8
how bout the trigger i see on evo its injector 3 (pin2)does it matter if it 1 2 3 4 injector?> |
I have just done a EVO/MBC specific wiring diagram - I tried to be as accurate as possible.
http://www.aquamist.co.uk/forum/gall.../HFS-1-MBC.gif |
Depending on how map switch is perform on a third ECUs, perhaps it requires enabling a ground to active a WI MAP - in such a case, ground pin12. Once you have establish the requirement, please post again. Great install !!! |
(Post 4679595)
cool thank you evo8
Yes. They are the same. One of the injetcor's pulse wire is Green. For ease of identification, I used that one.
diagram is perfect thank you !!
just one more thing i do not have a manual boost controller can i not use that option or can i some way hook it to my greedy electronic bc ? |
(Post 4680625)
