HFS-5 + 50 trim + not so good traction
Get those traction problems fixed and it looks like low 12's! Nice times none the less!{thumbup}
I noticed that spinning on launch allways gives a high 1/8 mph.
Was the run logged? |
Originally Posted by C6C6CH3vo
(Post 4874299)
Was the run logged? I was going to say it seemed a little low, either that or my car really dies up top. I trap 117.1 in the 1/4 but I hit 93.41 in the 1/8. He is not getting as fast in the 1/8 but is faster in the 1/4. Although, my sixty foot times are .3 to .4 better so I wonder how that affects it. |
Originally Posted by dudical26
(Post 4874337)
Hmm, do you really think that 1/8 MPH is high based off the 1/4 MPH.
I was going to say it seemed a little low, . |
wow on the 60's ...what was the tire pressure at?
(Post 4874365)
92 mph is not slow for 8.0sec in the 1/8, and I don't remember saying "1/4 was based on 1/8 mph" either. But one thing, even if traction wasn't a factor and he saved like 0.3 seconds on the 60', the mph would still be kind of high for the 12.0sec 1/4 it would have been, don't you think?
I don't mean to claim that you said 1/8 was based on 1/4, I am saying that for nearly 121 MPH trap, I would expect to see higher 1/8 mile MPH. |
You guys have to remember in those runs, I was feathering the throttle due to traction issues on 1st and 2nd gear. The rpms would hit so fast that I couldn't help but hit the rev limiter.
Anyway, I just did a boost leak test last night and found out that my HKS Bov was leaking, I could actually spin my bov around.:lol: The C-clamp was not flushed all the down to the flange which caused a major leak. I also found another leak at the meth nozzle fitting area. No wonder why I could not hold 27psi of boost, it would taper down to 25 or 24 psi of boost. I fixed all the boost leaks and its holding boost all the way to redline. The evo pull much harder then before.:thumbup: |
Originally Posted by milo
(Post 4875848)
(Post 4875867)
boost leak tests are super important, nice going. You should see if you need to re-tweak your tune and then get back to the track
I pretty sure I'll have to get a retune considering it was a major boost leak. I'll be upgrading to a T61 hopefully next week so, I'll just wait for the retune then.:thumbup: |
(Post 4876481)
Yeah.......I completely agree with you on checking for boost leak, everyone should do this test. I'll probably do the boost leak test once a month since its so simple and easy to do.
I pretty sure I'll have to get a retune considering it was a major boost leak. I'll be upgrading to a T61 hopefully next week so, I'll just wait for the retune then.:thumbup: O man, bigger turbo:) . Are you trying to reach a certain HP or track goal or just want more power? |
(Post 4877126)
(Post 4877533)
D. ALL THE ABOVE:lol:
(Post 4877533)
You might want to invest in some drag radials. |
(Post 4877851)
What are your track goals?
You might want to invest in some drag radials. Mid to low 11's and trap spee around 125-128mph would be awesome......I'll go to the track again this week and see if I can at least get in the 11's As for drag radials how good do they stick? |
