Aquamist HFS-6's advanced algorthm explained...
http://www.aquamist.co.uk/forum/gall...6/trimmers.gif Quick summary of the functions of the HFS-6's main control panel http://www.aquamist.co.uk/forum/gallery/HFS6/panel.gif Jumper links (default): - System is triggered by Fuel IDC % (second from left) - Spare jumper link is in parked position - Water injection is enabled. Unlink for "dry-run" test Three onboard LEDs - Green LED: Fuel idc detection. Grows brighter as IDC increases - Amber LED: The trigger point is reached, water injection commences - Red LED: The water injection has almost reached its full flow. Potentiometers to manipulate the flow curve. (Adjustment is optional - preset at 12 o'clock) - THRES ADJ: Set triggering point to start injection. Default: 42% IDC - IDC TRIM: Add or subtract IDC% from the starting point. Default: IDC-in = IDC-out - IDC gain: Alter ramp rate of the IDC-out relative to the IDC-in Default: 1:1 ratio. - BOOST COMP: Increase the flow to offset the manifold pressure. Default: 2.5V - FLSF SENS: Failsafe sensitivity/response to over or under flow spikes. Default: 400mS - FLSF RST: Failsafe reset time after trigger. Default: 3 seconds - DIM ADJ: Gauge brightness for night driving: Default: 50% |
Test run the HFS-6 with this DUD-Tool (ms-excel based) and see how those potentiometers functions. http://www.aquamist.co.uk/forum/gallery/HFS6/DUD/1.gif http://www.aquamist.co.uk/forum/gall...6/trdt-v50.gif http://www.aquamist.co.uk/forum/gall...6/trdt-v50.gif |
interesting
How Much shipped to Florida?
i want one{thumbup}
Man that is cool. It seems that the HFS-3 is very similar but without a few of the flow tuning options. I like it how you can control flow based on boost level and IDC%. It is also nice that you can trim the gain as well as simply add more IDC%. This would be extremely helpful for tuning more difficult setups that need some tweeking.{thumbup}
I have been playing with different gain setups, flow restrictors, and jet sizes. By adjusting these things I can alter the flow curve of my HFS-3. I could not even imagine all the possibilities of the HFS-6. |
| All times are GMT -7. The time now is 07:07 PM. |
