My dyno #'s
Old Jan 23, 2006 | 08:53 PM
boosten's Avatar
My dyno #'s
I just found my dyno sheets today after they went missing for 2 months. I hate when you move!!!!!
This is on 91 pump TBE K&N Drop-in APS FMIC ECUTEK NO BOOST controller except for ECUTEK
Old Jan 23, 2006 | 09:26 PM
702RSevo's Avatar
vergin evo?
Old Jan 24, 2006 | 08:11 AM
gaijin's Avatar
Originally Posted by 702RSevo
vergin evo?
Yeah I noticed that too. Maybe Rich doesn't have to worry about spelling 'cause he is such a baller.
Old Jan 24, 2006 | 08:59 AM
b0ostedEV08's Avatar
That A/F.....hmmm.
Old Jan 24, 2006 | 01:17 PM
housedj's Avatar
Originally Posted by b0ostedEV08
That A/F.....hmmm.
yeah what he said. A/F looks like booboo. this is an example of why u don't go to a Subaru tuner to get an EVO done...
Old Jan 24, 2006 | 06:09 PM
Spec C's Avatar
I think people mistake a person that can get a desired result out of a car for a tuner. A tuner can tune anything, not just one kind of motor. A tuner takes the data at hand and finds where the motor is happy, and puts it there. It might take a tuner longer to do this to a motor he is unfamiliar with because he doesn't have an idea of where it may want to be, but a real tuner will get it there.
Running and evo at that afr is ridiculous, infact running a subaru at that afr is ridiculous..
Old Jan 24, 2006 | 07:09 PM
boosten's Avatar
12.66 @ 108 on pump Thats all I care about
Old Jan 24, 2006 | 08:26 PM
boosten's Avatar
Can someone fill me in on whats wrong with the A/F ratio? Is it because its not smooth or still a little to rich?
The car does not show me any problems at the track (I.E.) ET/MPH
Old Jan 25, 2006 | 08:39 AM
housedj's Avatar
look at how FLAT the stock A/F was how it went from 14 to 10 & STAYED there???
your "tuner" should have done the same thing after the flash except that it should have been 11.5:1 for your pump gas tune. not only would be most likely be making over 300whp, BUT you also be going faster in the 1/4 so that way you would have a FASTER time to CARE ABOUT.
then imagine for a second,,,, how your car would respond to a race gas tune of 101octane unleaded or higher where you can throw in 20 degrees of timing...
Old Jan 25, 2006 | 08:56 AM
Spec C's Avatar
Not entirely true, but you make some good points and i agree with most of it..
Some tuners like to dump a little fuel up top to keep egt's incheck.. But i do agree it way to rich, and should flatten out for longer. If he leaned it out he may not make huge power gains, but it would be a definite improvement.
I also agree evo's really start to get fun on some good gas. I gotta stop being so lazy and install a WI/Ai kit.
Old Jan 25, 2006 | 12:21 PM
Your A/F is fine, just looks a little unstable creeping down to rich. Being richer on the top end is safe, but if the transistion to rich is smoother, it would have made more power. And I know exactly what is going with the High Octane Fuel Map in your ECU by looking at the A/F...that's why I said Hmmmm...
But it doesn't matter, your car is fast with no detonation problems, and that's all you need to worry about.
Old Jan 25, 2006 | 01:30 PM
boosten's Avatar
A/f
I was under the impression that the A/F meeter they use does not read under 10.1 thats why it was flat at that point. I could be wrong but when we did dyno the car it fell of the chart at that point.
Old Jan 26, 2006 | 06:30 AM
joebud's Avatar
Boosten, your car is strong for your mods
There is nothing wrong with your a/f. remember we use this 91 octane **** water here. it may look unstable to the untrained eye but this dyno has such a fast sample rate (over 500 times per second) not an average like most dynos.
Yes you tune Subarus a little differently but Rich has experience and very successful tuning both.
Old Jan 26, 2006 | 08:54 AM
Ben - EcuTeK's Avatar
Hey guys,
1- People don’t realize that dyno dynamic machines max out at 10.0:1… they do not graph any lower unless calibrated to do so…
2- afr is a little rich above ~5.5K, but it depends on what timing is being run…
Also, it was well said by Joebud, your car run's strong and the little bumps in the A/F ratio is only due to the scaling of the graph. If ANY tuners out there could show me a absolutly perfect curve of A/F ratio, there has to be something wrong about the readings...
Keep enjoying your car and try using all that power to the ground !
Evo-IX-MOMO248
Jan 20, 2011 10:56 AM
EvoAidy
Apr 28, 2010 07:35 PM
itsoem
For Sale - Wheels / Tires
10
Apr 13, 2010 02:34 PM
itsoem
Apr 22, 2009 12:43 AM
YoungMoney45T
Apr 5, 2008 11:51 AM
