Turbo help
Old Aug 15, 2003 | 11:46 PM
Charles1's Avatar
Turbo help
ok im about to get a custom turbo installed but there one prob. Whetre do you get the oil feed line taped into. Or do u get the feed from the oil pan or is that only for the return line that uses the oil pan and the feed comes from as the block can some one help me out a little more please and if possible post pics.
Old Aug 16, 2003 | 10:59 AM
J'sLancerLS's Avatar
I believe the feed line taps into the housing where the oil filter screws on and the return line goes into the oil pan meaning that you have to drill and tap a hole on the pan for the return line. Check with boeturbolancer or ROCK, they are the masters with that stuff!
