Las Vegas Evo's
Damn, Thanks Casey... I will oreder it through Lancershop tomorrow. 74+ @ the dealership... f'ing rapists.
IE: are you offering me the BOV for sale?? I don't want one. Had the GFB, it sucked. Will wait until AEM EMS to go BOV again.
Can anybody confirm this info?
Transfer case: GL-5 DiaQueen LSD Gear Oil, 90weight, part #377601, Approx 3 quarts needed, at Mitsu
Transmission: Pennzoil Synchromesh Fluid GL-4 SAE90 or 75W-90, Approx 3 quarts needed, at Auto Zone
Did a search and this is about the straightest answer I could find. Any clutch experienced individuals are welcome to provide input...
Thanks!
Thanks!
Originally Posted by IE Evo
I like my GFB but at 28 pounds of boost I went with the Vishnu recommendation. No I was not sellin to u. Casey mentioned it but I will sell it in the classifieds for 100 bucks along with the GFB. GFB =Pssssshhhhttt.
Thanks!
Thanks!
TC= I used Redline also, 75W90 API GL5+ Hypoid Gear Oil, but now this is where I get bashed by everyone on this thread casue it's not OEM. Casey uses Redline also and his tc hasn't blown up either. You shouldn't need 3 qts. When changing the fluids I only used .58 qts I think is what the manual says.
IE: What does a throw out bearing look like, and should there be one in the box with my new Exedy twin disc??
Originally Posted by EvoallovEr
tranny is 2.9 qts ( i measure) I just switched over to Redline MT-90 and love it so far way smoother than OEm ever was
Now where in Vegas do I get Redline (if I go that route)??
You just drop that exedy twin disk off at my house and I'll check it out for ya, make sure it's safe and all
double post
