Las Vegas Evo's
Gonz, here is the complete solo rulebook if that helps. SCCA.com definitely has alot of info for you.
http://www.scca.org/documents/Solo%2...lo_Rules_2.pdf
Great! Its $2.99 at Rebel now. Not bad for 105octane alcohol. Car runs cooler, A/C even colder if you can believe that. the milage is not bad at all. I used to get about 180-200mi a tank on 100/meth. Now I get 160-180 per. Anything under boost is leaned out for milage, Running 30 psi with no knock counts period. Its got more in it but I just wanted to make same peak as 100/meth with more under the curve. And thats what it is. Very satisfied
I know I havent been on the board much. But the wife and I are working on our "guns"
Hope to move back to Indiana in the spring to follow my dreams of opening my own gym.
Gotta spend some time to look the part.
BTW, we want to go out with a bang. Its been awhile but we want to start clubbin again. Lost all my connects. If anyone has a hookup please give a PM.
We want a summer/fall to remember what vegas is all about if you know what I mean.
Will post agin when I get home, bu tI think the new Rebel on the corner of Nellis and Vegas Valley was even lower than $2.99 for E85. I think it said $2.65 or something!
Will update with correct info later!
Scott
Scott
So far i have used E85 from 5 pumps in vegas.
Good (car didnt start knockin)
Town Square
6085 S Rainbow Boulevard
Trop Stop
4885 West Tropicana Avenue
Also another on north vegas blvd... It was an Eco... something station.
bad (smell weird, and added knock)
Hotspot (fuel smelled weird)
4708 W Charleston Blvd.
Lucky Stop
8816 South Eastern Avenue
I spoke to the truck driver delivering the E85 one day. She said that all the E85 pumps in vegas get their fuel from the same place, however, what was in the tank before the E85 is questionable... Also, the further west you go the more expensive it will be. The fuel depot is in the east... less miles to transport=cheaper e85
Im not logging every tank of E85... I probably should... i probably should be logging and dialing in the tune also.. but ive only got a few more weeks in Las vegas... After moving i will probalby go back to 91. Quite depressing.
Town Square
Trop Stop
Lucky Stop
Im in hendertucky so use the rebel on sunset/sunset and some po dunk place on bldrhwy near sunset. I have filled up at one rebel near the strip once. I'm not logging everything either, but I have the utec that has a knock light. it don't flash so all is good.
