Las Vegas Evo's
Originally Posted by joEvo8
How much are stock clutches?? Thinking about just ordering a stock clutch with a light flywheel.. My current clutch still grabs and I know I'm capable for 12.1 or 12 Flat.. That first night of MM i had to adjust to my new tune.. thats why it took me 4 runs to get into 12.3 still working on my shifting points.. I shift early due to I'm a dumbA$$.. 1st-2nd 7000+rpms, 2nd-3rd 6500-6900 rpms, 3rd-4th 7000+rpms... my last run I had a 1.7 60 ft but I shifted early on 2nd to 3rd, could of made a lower time..
Originally Posted by IE Evo
the Silver one is Joe and yes he is usually on Dubs -1 but he borrowed some stockers and more than caught up with Jon. 13.1s are going to be messed up runs for Joe for now on. Low 12s will be the norm.
Originally Posted by trevotec
I think I have raced that z06 but I will race him again. Is it ZO6ICK.
I start Swing shift today.. 3pm- midnight.. I dont think I'll have time for the meets again.. but I'll be tryin to switch my Sched.. and for sure I'll be off for race days... but I wont be running this Thurs.. MM is what I'm saving my clutch for and when IE brings in my juice (VP 109)
Jon, I would like to get those tires from you.. the stock ones.. why dont I just give you my wheel & $40 and you just give me the wheel & tire??its just less work for me. I have to put it on and balance it..
Originally Posted by lil'evil_evo
Don't buy another oem clutch. Get either a Exedy twin or at least a single. I have no idea why you would want anything other than a twin with the power your making?
I think this is a miss print Ron.. I did 13s cause people were telling me how to drive.. after I stopped listening I hit all 12s.. and I messed up once and that was a 12.6.. 12.5-12.7 will be me messing up from the launch.. When I launched for the 13s.. I F'up really bad.. the 1st time tires wouldn't grip and missed 2nd.. 2nd time Tires caught grip but not at the right rpms and I Bogged!..
As far as ur driving style u do need to shift a lil above 7000 rpm with your set-up and the 3-4 shift is most crucial for great times. Cams push ur power to the top end and above 6500 rpm there is power.
Also Smoggy used to just dump the stock clutch when he raced at the track and his clutch lasted 25 k + miles with several drag launches. FWIW I have over 100 launches on my Cusco Twin and it still is holding power for some reason.
I dont want to spend the excess money for a aftermarket clutch when my clutch is still pretty good.. Its grabbing and holding all that power. but once i hit 11s.. I'm done for the track and I'll just be saving up cash and tear & wear on the car..
Oh I guess I thought $$$ grew on Trees?? But Still trying to figure out to go with Cusco or Exedy.. ? If Cusco can handle IE's monster.. then I'm leaning towards that one.. I'm still going to run the Next MM with my current clutch... as long as I take car of it. like i usually do.. it should last..
i'll have them off the car for good this week.i'll meet up with you or something to make the switch
