WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
works p2 269 cam flash
Old Nov 5, 2004 | 06:35 PM
mattsgto's Avatar
Would the 269 cams p2 flash work well with the 10.5T exhaust housing if i were to install it? I was curious about that.
Old Nov 9, 2004 | 01:34 PM
Jamie@WORKS's Avatar
The larger exhaust housing allows for more flow at high RPMs. The WORKS 269 cams should compliment it well.
Old Jan 14, 2007 | 04:27 PM
sud0u's Avatar
Would it make any sense if I get the 269 Cams and retainers if I have just a P2R flash and intake as mods? Do you guys recommend another component prior to the 269 Cams? I am planning to get this done with a timing belt replacement from you guys in the next 600 miles.
Thanks Works,
Anthony
Old Jan 14, 2007 | 04:59 PM
boostingevo8's Avatar
I have 269 cams in my car ( installed by prior owner) AT 22psi on a Mustang dyno I only made 284 whp. I also have a DC sports downpipe/no cat, and an Invidia N1 exhaust. My buddies with HKS 272's and such are all over 300 whp with same Mods......as I thought I'd have atleast seen 300 whp.
Although on a dynojet I am just above 300 whp, so I guess it's really depends on where you'd like the power in the powerband too.
Old Jan 23, 2007 | 09:39 PM
NiteRider's Avatar
I noticed in your sig it says you ran a 12.68, what do you buddies run with the HKS 272's?
Old Jan 24, 2007 | 01:30 AM
To be honest......they aren't running much better tiems than me...(12.40's 12.10's) but all trap higher than me like 110mph to 113mph. My 12.68 was only my 2nd pass ever too..... I think these 269's cams are really geared toward spreading the power out evenly throughout hte powerband. The 272's and such just have more top end.......
Old Jan 24, 2007 | 10:34 AM
That sounds pretty accurate. WORKS engineered the 269 Power Cams to have broad, useable power across the RPM band. We did not engineer them based on peak output. Our goal was to generate a graph that looks more like a plateau than a pyramid. Even so, we see minimum "peak" gains of +29 ft-lbs/+29 HP on the VIIIs with further improvements elsewhere in the curve.
