WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Help With Ralliart Clutch Install
Old May 26, 2005 | 05:24 PM
bigdoggy_dog's Avatar
I've been trying to install this line and everything is cool except for the banjo bolt at the rear of the engine bay. I can't find a way to get to it get it off and put the new line on. Anyone have help for this?
Old May 26, 2005 | 05:36 PM
Compjoc's Avatar
Are you talking about the Works TKS clutch line?
Old May 26, 2005 | 05:38 PM
Jamie@WORKS's Avatar
It's a tedious process. We've found a flexible head Gearwrench (or something similar) tends to work best. It can be done with standard wrenches, but this one just aids the process. No matter what tool, it's still one of our least favorite installs
Old May 26, 2005 | 05:49 PM
TylerO@WORKS's Avatar
Small hands help for sure
I use a standard 17mm wrench...
when you are installing ours, make sure to start with the banjo bolt then work your way down...
GOOD LUCK!
Cheers
Old May 26, 2005 | 06:31 PM
I went the opposite way and went from the restrictor up. Either way I can't find a way to get to that damn banjo bolt.
Old May 27, 2005 | 08:34 AM
slt's Avatar
slt
I made my g/f do it. She has small hands.
Old May 27, 2005 | 10:30 AM
You should really start from the banjo bolt, you can use the free end of the line to help you, holding it in place...
Old May 27, 2005 | 08:12 PM
It's a nogo. I just gave up and called the shop to take my car in. I just got too frustrated with it. I don't see how you guys could get a wrench in there.
Old May 28, 2005 | 10:18 AM
Hey Tyler and Jamie, I just wanted to say thank you for you help. I went at it again and I finally got it installed. It was tricky getting the banjo bolt back on without losing the bolt or the washers. I actually used a little trick. I grabbed a small rubber band that my daughter uses for her hair and wrapped it around the bolt and washer. This allowed me to manuever the bolt in place with one hand without fear of losing anything.
Either way everything is good to go now. Love the new clutchline.
Old May 31, 2005 | 03:51 PM
Good to hear
Old May 31, 2005 | 04:07 PM
Thats a pretty nice Lancer, just missing a FMIC and turbo kit... then you will be set!
