WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
AFR questions & Works P2
Old Jun 23, 2005 | 11:17 AM
RazorLab's Avatar
Originally Posted by jansolo
I am confused. Did anyone say that the Dynojet was load based?
Exactly my point. Why did you post that showing AFRs if you know that isn't a load based dyno?
Old Jun 23, 2005 | 11:19 AM
EM@WORKS's Avatar
Marksae, What is the date of that dyno run? The peak torque is way too late. I think the load on the dyno has been adjusted differently since your dyno run was done.
Old Jun 23, 2005 | 11:22 AM
marksae's Avatar
5/28/05. I have Helix intercooler pipes if that makes any difference.
Old Jun 23, 2005 | 11:28 AM
RazorLab's Avatar
AHHAH, what the ?
here is one taken the same day. Ooh look the peak tq location is different than Marks, couldn't be because its a different evo with different mods?
And another one taken a week later, same car, more mods and different tuning. Look, the peak TRQ moved again!
Old Jun 23, 2005 | 11:31 AM
marksae's Avatar
Originally Posted by razorlab
AHHAH, what the ?
Didn't you use 4th gear since you have an MR? Won't different gearing affect where the peak value occurs?
Old Jun 23, 2005 | 11:41 AM
MTMS4's Avatar
How are AFRs measured on the Dyno?
I know for wide-band meters such as Zeitronix, PLX etc. they recommend placing the sensor about 24 to 36 inches downstream of the engine block or turbo, basically screwed into the the DP just before the cat.
Has anyone here checked the AFR on their own wide-band during the dyno run (if that's possible?).
Old Jun 23, 2005 | 01:13 PM
jansolo's Avatar
1. Someone asked for a dyno chart.
2. No one specified they wanted a chart from a load based dyno (until your comment).
Old Jun 23, 2005 | 01:34 PM
EM@WORKS's Avatar
Dynojets are inertia based dynos. When doing sweep runs, there isn't much fudging/tweaking that can be done to change the results. Therefore they are usually very "honest."
Load based dynos require lots of time to calibrate properly and need to be constantly adjusted for different types of vehicles. The idea is to simulate your vehicle driving down the road (load) where most of your EVOs spend their time. Lots of datalogging needs to be done on the road to determine how to properly set-up the parameters for the dyno. And again, each vehicle is different.
Therefore there is a lot of variability with load based dynos depending on the amount of time invested in their set-up for each vehicle.
Old Jun 23, 2005 | 09:42 PM
SouthernCrane's Avatar
here are my dyno graphs with AFRs. sorry for them being blurry i don't have scanner.
Attached Thumbnails AFR questions & Works P2-dsc00495.jpg   AFR questions & Works P2-dsc00496.jpg
Old Jun 23, 2005 | 10:59 PM
TarmacEVO's Avatar
my dyno graph
Here's my dyno graph...
Anyway, Jamie, thanks for the PM. I will give you a call later.
Gabe
Old Jun 24, 2005 | 11:01 PM
TarmacEVO's Avatar
road data logging results
I spent several hours at Works this afternoon. They put my car on a lift, swapped in a test pipe, and hooked up all of their data logging equipment.
During a 3rd gear pull on a downhill on-ramp the AFR peaked around 11.79. During a 3rd gear pull on a slight hill with a shallow rise and fall the AFR peaked at about 11.3. During another run it was about 11.5 to 11.6 (I believe this was more of a flat road).
Therefore, when there was less load (downhill) the reading was a bit leaner. On the slight hill (more load) the reading was a bit richer. The readings were a bit richer than the dyno at all points. One of the biggest differences between the dyno and road logging was the shape of the AFR curve in the 5-7k rpm range. On the road data it is fairly flat, but on the dyno it climbs quickly.
Overall, Pete and the rest of the works gang believes my car is completely safe and I shouldn't worry about it. Now I can rest easy.
Pete, Tyler, and Jamie...thanks for your time and effort! You have reconfirmed why I chose Works in the first place
Old Jun 24, 2005 | 11:34 PM
Alias's Avatar
Overall, Pete and the rest of the works gang believes my car is completely safe and I shouldn't worry about it. Now I can rest easy. If anyone wants to see some of the road data, then shoot me a PM with your email address.
This is good info, thanks for letting us know!!
Old Jun 24, 2005 | 11:43 PM
RazorLab's Avatar
what was AFR up top?
Old Jun 25, 2005 | 08:01 AM
TarmacEVO's Avatar
here are some graphs from the road logging
I'm not sure what you mean by up top, so here are some graphs. The graph on the left is slightly downhill and the graph on the right is slightly uphill.
Old Oct 16, 2005 | 02:11 PM
ZeeGermans's Avatar
Originally Posted by TylerO@WORKS
Logging on the Road or a properly set up and calibrated dyno has show again and again that our AFRs are perfect. If anyone has any doubts feel free to come in and we will hook up all of our equipment so you can see the perfect AFR for yourself. Or head up to a dyno that is set up perfectly like the one at San Rafael Mitsubishi.
I'll quote my self from another thread:
/thread
I got this result at SRM last weekend. My AFR climbs to 11.8 by 6350 RPM and stays high. Also I see a major drop in power right around there. My car did not have this problem with the state of my P2 back when I dynoed in February. Something is wrong with whatever map that is, I think.
