WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
WORKS Engineering News
Old Mar 24, 2006 | 10:22 AM
EM@WORKS's Avatar
WORKS CK3 Twin Plate Push Style Clutch
Testing for the WORKS CK3 Clutch is progressing flawlessly. Almost too good.
We carefully engineered each component along the way (throwout bearing, hydraulics, pressure plate, discs, flywheel) and test fit them with ultimate precision. We have a bunch of motors on engine stands and a specific bell housing with a gaping hole in it to take careful measurements as we R&Red the assembly four times before committing to installing the first complete kit into our Race Car. Pedal pressure is only about 10% stiffer than stock and the pedal throw is about 35% shorter. It feels like a clutch should. Especially if you are used to typical push style clutches. The take-up is a bit more aggressive (no springs in discs) but surprisingly very manageable with easy modulation. Most people won't even notice. The engine winds up much faster with the lighter assembly and when it hooks up, watch out! It doesn't let go. We are experimenting with different disc materials which will also dictate capacity so stay tuned. We should have kits in production by this summer and a few early kits for enthusiasts to test at a discount. Details for this will be in the WORKS Spring Newsletter.
Old Apr 20, 2006 | 07:53 PM
Fisher22's Avatar
can you give us an estimate on the cost? i'll definitly be needing a new clutch after this autox season
Old Apr 20, 2006 | 07:59 PM
voidhawk's Avatar
One more Q: will it fit the MR's 6sp? Thanks.
Old Apr 25, 2006 | 03:08 PM
Jamie@WORKS's Avatar
We're estimating the CK3 to come in around $2000. We've done check fitments off the car with the 6-speed and will be installing one on a running vehicle soon. At this point, everything appears fine.
Old Apr 26, 2006 | 08:38 AM
voidhawk's Avatar
sounds promising, thanks for the update
Old Jul 20, 2006 | 08:05 PM
WhiteEvo05's Avatar
Fast forward three months...and...
Old Jul 21, 2006 | 05:31 PM
It's available Our webstore hasn't been updated accordingly, but that should be rectified soon. Stay tuned!
Old Jul 25, 2006 | 11:29 AM
DJ Brett B's Avatar
How does it compare to the Exedy twin disc clutch kit? I also want to know if it will fit the IX MR's 6 speed tranny
Old Jul 31, 2006 | 12:07 PM
PANGES's Avatar
^^^ I want to know this too because my clutch just gave out and my car's sitting in the garage... By the way, how much do you guys charge for a clutch install if I bring my own clutch?
Old Aug 24, 2006 | 01:36 PM
Ink's Avatar
Ink
+1
Old Aug 29, 2006 | 06:05 PM
Yes, it will fit the 6-speed transmissions. It's hard to compare the two as it is highly subjective. With the push-style setup of the CK3, the pedal becomes lighter and much easier to modulate. The holding capabilities of the twin discs have been more than sufficient for even the Time Attack EVO.
Old Aug 31, 2006 | 09:01 AM
20psiMR's Avatar
What did the price come in at jaime? What material are the discs? I cant see paying 2k for a clutch unless its twin carbon, could pick up the RPS for a little more and its rebuildable.
