WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Croxx Plate II
Old Mar 25, 2006 | 08:27 PM
Russell K's Avatar
Croxx Plate II
http://www.worksevo.com/store/produc...products_id=39
I am really interested in purchasing this, but one thing concerns me, do you have to remove it every time you change the TC fluid? It looks like it may block the drain plug for the TC. I really dont want to remove this thing every time I change the TC fluid.
Old Mar 26, 2006 | 06:53 AM
marksae's Avatar
I have the Croxx II and just changed my TC fluid yesterday. You can get to the drain plug without removing it, but the plate will block the fluid draining out. So yes, you need to remove it in order to change the fluid. It's not a big deal since it's only 5 bolts. Perhaps WORKS will should add a notch in it for this on the Croxx III.
Old Mar 26, 2006 | 08:59 AM
redvolution's Avatar
Yeah - the croxx plate trivial to remove and pretty easy to replace - far easier than dealing with the all that plastic under the nose.
Old Mar 27, 2006 | 04:58 PM
Jamie@WORKS's Avatar
Mark, swing by the shop and I'll drill a hole in yours as a prototype
Old Mar 28, 2006 | 08:38 PM
dayf's Avatar
Will this plate prevent the motor from dropping in a frontal collision? (odd question.. I know..)
Old Mar 29, 2006 | 01:46 PM
It shouldn't affect what the engine does in a frontal collision as it mostly covers the subframe area.
Stock:
Croxx Plate:
Old Apr 20, 2006 | 06:08 PM
Autogasm's Avatar
does this clear turboxs 3inch tbe?
Old Apr 20, 2006 | 06:23 PM
Danny23's Avatar
so you dont use the plastic undertray with this installed,and will it clear a 2.5 dp into the stock cat with a buschur 3inch cat back
Old Apr 20, 2006 | 07:51 PM
GotLeon's Avatar
It works with the stock plastic undertray. It also works fine with the larger Beatrush aluminum underpanel.
Old Apr 21, 2006 | 02:08 PM
Autogasm's Avatar
? waiting to heard, before I buy
Old Apr 24, 2006 | 08:19 AM
ovenmit331's Avatar
it clears the WORKS 3" TBE...
Old Apr 25, 2006 | 08:29 AM
silverflyer's Avatar
I would think so but I dunno
Old Apr 25, 2006 | 03:21 PM
With the Croxx II redesign, we've found it clears most 3" DPs. The only ones we seem to have issues with are the custom jobs involving one-off DP/big turbo combinations. Even then a little machining allows everything to bolt up fine. As mentioned, the stock plastic undertray remains fully intact and functional.
tnguyen
Lancer Aftermarket Forced Induction Tech
Mar 17, 2016 08:16 PM
DanJ
21
Dec 21, 2007 08:07 PM
kirk@WORKS
Jun 17, 2007 12:43 PM
Jamie@WORKS
Evo 'For Sale' Suspension / Brakes / Handling
Dec 12, 2005 04:36 PM
