WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Ohlins Stage II, III Ride Height settings
Old Apr 21, 2006 | 08:51 AM
evoracerx's Avatar
What are the height settings that you recommend for these 2 systems? I.e. wheel center to fender distance or how much more gap in the front than the rear. I'm running your the Ohlins R/T with 450F 400R rates.. I am redoing my alignment and replacing bushings for up coming track events this weekend. Sorry I live to far away from you gouys to go to your shop. Thank you for your help, if you would prefer, PM me the specifications.
Old Apr 21, 2006 | 02:24 PM
mmoranda's Avatar
Drop it till it rubs. What rims/tires are you runnin?
Old Apr 21, 2006 | 02:39 PM
evoracerx's Avatar
SSR Type C 17 x 8.5.
Old Apr 24, 2006 | 08:42 AM
evoracerx's Avatar
bump, kirk, can you respond to my pm
Old Apr 24, 2006 | 09:53 AM
meanmud's Avatar
Pretty sure that's not correct - research it a bit
Old Apr 24, 2006 | 04:44 PM
mmoranda's Avatar
Well what I mean is depends on his spring rates. Also depends on his ofset rims. My car doesn't rub anywhere but on the lefthander after the corkscrew at laguna. So drop it until it rubs then crank it up until it doesnt. I currently have 450 front 500 rear.
Old Apr 27, 2006 | 01:53 PM
evoracerx's Avatar
bump, need some answers Ali and Kirk
Old Apr 27, 2006 | 03:50 PM
Ali@WORKS's Avatar
Ohlins ride height numbers
Hello, sorry for the delayed response. The ride height settings are as follows. For the front struts. 50mm from the bottom of the spring perch lock ring, to the end of the threads. And for the rear 40mm from the bottom of the locking ring to the end of the threads. This should lower your car with the correct balance. The ride height numbers are as follows. From the centerline of the axle to the edge of the fender, approximately, Front: 14.75" Rear: 13.75"
Old Apr 28, 2006 | 08:45 AM
TPetsch's Avatar
Thanks Ali.
At these “recommended” settings approximately how will the front and rear sit compared to OEM ride heights?
Old Apr 28, 2006 | 11:52 AM
Jamie@WORKS's Avatar
Originally Posted by TPetsch
Thanks Ali.
They are about an inch lower than stock.
Metal
Jul 3, 2016 06:29 PM
RallySport Direct
Evo 'For Sale' Suspension / Brakes / Handling
157
Dec 30, 2014 07:18 AM
Bill@WORKS
Apr 9, 2009 08:58 PM
DimitrisIX
15
Apr 18, 2008 03:41 AM
pao
Oct 9, 2006 07:20 AM
