WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Do I need these items?
Old Sep 1, 2006 | 03:50 PM
eling99's Avatar
Im gonna get the work cams, spring and retainers. I just order the power enterprise timing belt. do i need to buy the idler pulley,tensioner pulley, and timing tensioner? http://www.slowboyracing.com/more.php?id=2031&
somone local will help me install this!!!
Thanks
Old Sep 3, 2006 | 01:11 AM
Boosted GP's Avatar
Depends on the milage of the car, but since my car was new (3000mi) I didn't do any of the belts or tensioners, left all the stock items in.
Oh, did you get my PM?
Mike
Old Sep 11, 2006 | 04:09 PM
Jamie@WORKS's Avatar
You won't "need" them until you start racking up the miles. It's not a bad idea to replace the hydraulic tensioner if it's coming off the car, but if you have relatively low miles, it's usually safe to stick with the original provided nothing goes awry during the install. Anything around 50K-ish mileage wise, it would be something to consider. If you need any OEM parts, we can provide them for you as well for about 10% less than the dealer. We have a number in stock (including all the items linked to above) with others just a phone call away.
Old Sep 20, 2006 | 10:49 AM
Just to follow up on this... I installed a set of WORKS 269 cams this past weekend and noted a couple of things. It seems the hydraulic tensioner was overcompressed from the factory and was causing it to leak (or at least allow fluid/dirt to collect near its seal). The balance belt tensioner pulley also had indications that it was leaking. Both were replaced (with about 39K miles on them) as precautionary measures.
