Works/Ohlins sus. ????
Works/Ohlins suspension?
Besides ride height adjustability, is there a significant difference in performance between the works/ohlins stage 1 and works/ohlins stage 2...assuming spring rates and damper settings are the same?
Yes, The Stage I is designed for street use and mild spring rates up to 5kg. The Stage I is a non-height adjustable OEM style replacement that is comparable to the MR Bilsteins, with the added feature of damping adjustment. The ride is very comfortable, however our track enthusiast customers tend to prefer a more aggressive system.
-Spring rates are limited w/ this system since it is not a full coilover setup.
-Best suited for the street customer who owns a GSR or RS and wants an MR Bilstein setup w/ superior damping.
The Stage II is a full coilover system w/ height adjustment and damping. Stage II is designed for more agressive spring rates (typically 6-10kg).Body Roll is significantly reduced compared to OEM style struts.
-Spring rates can be customised as well giving more range of adjustability.
-The other advantage of this system is that the coilovers can easily be re-vavled for higher spring rates if needed.
-Best suited for the Evo owner that tracks/ auto-X their car yet still drives it on the street.
If you have more questions feel free to call us M-F from 10am-6pm.
Off to SEMA....
Off to SEMA....
