WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
P2R flash and AEM Tru-Boost
Old Dec 15, 2006 | 02:56 PM
guyver858's Avatar
Can I run both of these at the same time? Can I have the P2R flash control boost in conjunction with the AEM tru-Boost controller?
Old Dec 16, 2006 | 12:31 PM
guyver858's Avatar
anyone? works?
Old Dec 19, 2006 | 10:14 AM
Jamie@WORKS's Avatar
You could run the WORKS Brain Flash software and use the add-on controller, but I wouldn't recommend using the add-on controller with the WORKS boost hose assembly. Using the above by itself would bypass the ECU's capability of controlling boost. It could be possible to physically run both the original boost control solenoid in conjunction with the above. However, this would put two different modules working to control the same function. Chances are there would be some conflict and one (or both) would need to be tweaked in order to maintain smooth, consistent and safe boost levels.
