WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Works package
Old Aug 8, 2003 | 12:18 AM
  #31
sharkster's Avatar
Originally posted by jess
I guess I'm pretty lucky for living close to Works. Next Wednesday I will have all three available mods (Brain Flash, Throttle Body and Exhale) installed while I wait. I'll try to get a before and after Dyno. Looking forward to the improvements. My EVO is stock with only 600 miles.
how much was it out the door since i live closeby too? thanx
Old Aug 8, 2003 | 10:14 AM
  #32
jess's Avatar
Out the door with $1481.00 bucks, but that also included the new Croxx plate. Brain, throttle body, exhale, croxx plate and labor all included in price. It's a good deal. It's a totally different car with increased smoother power, torque and a new throaty sound that's pleasing to hear. Roll on power is improved dramaticaly in 5th gear . I highly recommend it if you want stealthy mods.
Old Aug 26, 2003 | 08:47 AM
  #33
jess's Avatar
dyno with a/f ratios
Hey folks, I did 3 dyno runs yesterday at ATP in Fremont (sorry wilson1 forgot to PM you). I drove about 1.5 hrs to get there in 100 degree temps. I'll post the results as soon as I make a file and figure out how to post it. It was 98.9 degrees, 29.7 Hg, CF=1.02. My best run was 246.8 hp, 238.9 torque with a/f ratios between 11-12. very smooth curve can't wait to post them. WORKS is the way to go!!!
Old Aug 26, 2003 | 08:55 AM
  #34
N10S's Avatar
Jess, do you have the entire package w/exhale and aperture?
Edit: Sorry for asking that stupid question Jess...guess I should have read your previous post outlining that detail......sorry man
91 octane re-flash? Can't wait to see the dyno charts, thanks for sharing your info!! Btw - nice numbers considering the hot temps!!
N10S
Old Aug 26, 2003 | 09:10 AM
  #35
jess's Avatar
N10S
Yes, I have the 91 octane re-flash, aperture & exhale. I was pleasantly surprised to see those numbers as was the tech for such a hot afternnoon. Hopefully have it posted by lunch time today.
Old Aug 26, 2003 | 10:22 AM
  #36
caymandiver75's Avatar
Can't wait to see the numbers posted. If you need help posting just PM me.
Old Aug 27, 2003 | 07:28 AM
  #37
jess's Avatar
Ok, here it is. Keep in mind I drove 1.5hrs. in 100+ degree temps and straight on the dyno.
Old Aug 27, 2003 | 07:36 AM
  #38
jess's Avatar
Here is another with an overlay of a stock dyno done in June. Notice at 6800 rpm there is a 50hp difference along with almost 40 lbs of torque change. The changes are there and very noticeable on the butt dyno. This combo of the re-flash, aperture and exhale is the way to go!!!!!
Old Aug 27, 2003 | 07:51 AM
  #39
Looks like anything below 3500 the stock evo just works better. Drive with rpms over 3500 its obvious that the works package really makes a nice difference. I know there are a lot of variations between each day with the weather variables, but even with that in mind there is still a very noticiable difference with the ECU flash and works products. Can't wait to see what their new boost upgrade will do.
Old Aug 27, 2003 | 12:15 PM
  #40
N10S's Avatar
The stock dyno run probably looks better down low because the stock exaust variable flow flap is allowing for better low-end boost spool-up. Adding the exhale, or any axle or cat-back pipe for that matter, has been proven to reduce low-end boost by about 1 psi requiring some form of adjustment to bring it back up to the original spec.
Personally I bet if you added a boost controller, or when the Works Brain re-flash is made available you will see the dyno charts reflecting power gains down low as well as the mid to high rpm ranges where we already see the improvements today.
This will be a happy day indeed
N10S
Old Aug 28, 2003 | 07:15 AM
  #41
DavidV@WORKS's Avatar
A couple observations worth noting in Jess' dyno plots are how consistent the repeatability on the plots are with the WORKS Brain flash and the fact that the WORKS plots are actually smoother than stock.
Extra power is relatively easy to get out of a forced induction engine, but keeping it repeatable/reliable and actually making it smoother than stock is no small achievement.
Nice numbers, Jess. Thanks for posting these.
-- DavidV
Old Aug 28, 2003 | 12:19 PM
  #42
Yep the graphs look great. Very consistent and a lot smoother than stock.
Old Sep 7, 2003 | 11:38 AM
  #43
ricetezza's Avatar
did the prices for throttle body and exhale go down or are the prices on the site not including the brain reflash cuz i think they used to be higher
Old Sep 7, 2003 | 12:20 PM
  #44
umiami80's Avatar
ok, i SEE 245whp on the mods, but that is on 91 octane, right?
EVO's make 200WHP on 91 pump right? SO you are netting 46WHP with these mods, is that right?
Old Sep 7, 2003 | 12:54 PM
  #45
jess's Avatar
check out the horspower & torque difference at 6800 rpm, 50 hp and 40 lbs. of torque on 91 octane. The mods are Brain, aperture, exhale.
jake33
Sep 10, 2015 07:13 AM
Levar
Jan 24, 2011 04:07 AM
Indy Evo
Nov 11, 2009 04:03 AM
Indy Evo
Feb 13, 2009 10:36 AM
wilson1
41
Dec 10, 2003 12:24 PM
