WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Mechanical CEL Fix (O2 Fix) on WORKS IP?
Old Jan 3, 2008 | 01:05 PM
racer135's Avatar
Will the mechanical CEL Fix (O2 Fix) fit on the WORKS intermediate pipe. New versions of the fix look to be a little longer and I think it really depends on the location of the O2 Bung. If it is too high I guess it will not fit. Anyone using it?
Old Jan 3, 2008 | 01:27 PM
Tsurugi-san's Avatar
It works on mine!
Nothing special about my setup either . . . WORKS 76mm DP, RTP, and catback.
Old Jan 3, 2008 | 02:21 PM
Jamie@WORKS's Avatar
It will fit, just keep in mind that the sensor is pushed out and away from the tunnel beneath the chassis. We've seen a few sensor hit the sheet metal and become damaged (independent of exhaust, including the factory pipe). You can move the exhaust and see if the give on the hangers comes close to the floor. If it does, either don't use the extension or manipulate the sheet metal (using a hammer - air or otherwise) to help keep contact from occuring.
Old Jan 3, 2008 | 02:23 PM
"manipulate"
We have other words for that here in Arkansas.
Old Jan 3, 2008 | 02:57 PM
Old Jan 3, 2008 | 05:08 PM
racer135's Avatar
Originally Posted by Tsurugi-san
It works on mine!
Thats the same setup I ordered plus the filter and BF2. What I reall meant is that if the sensor will hit the sheet metal. So I guess it depends on the final location of the IP and the length of the O2 spacer. Maybe I can get a 90 deg spacer somewhere.
Old Jan 3, 2008 | 05:41 PM
Well,
My intermediate pipe bung with the O2 fix peice attached is completely horizontal. No contact. But a few degrees less . . . . and we'd be reaching for a hammer!
I know you can get an L-shaped O2 spacer if it's needed. I've seem them here on Evom.
Old Jan 3, 2008 | 06:59 PM
racer135's Avatar
Do you have the stock exhaust hangers or are you using polyurethane hangers?
Old Jan 3, 2008 | 08:03 PM
All stock hangers on the beast --- or, as the GF calls it, my OTHER girlfriend (which I spend more on, apparently).
