Works Croxx plate
What are the differences from the works croxx plate and croxx plate II? Also when it originally ships does it come with hardware as in spacers and new bolts or does it just use the original tie bar bolts? Any info would be appreciated!
Mike
Mike
The WORKS Croxx Plate was designed for a 70mm down pipe and the WORKS Croxx Plate II is designed for a 70-76mm down pipe. The kit does come with spacers and you would reuse the stock bolts that hold the front chassis bars in place. There is a set of comprehensive instructions in the box with the plate and spacers that will explain what bolts are used and torque specs for them.
They all came (come) with spacers. The difference between them is the hole in the plate. The earlier model of WORKS Croxx Plate had a hole that was designed to work with a 70mm or smaller down pipe. The newer model has a bigger hole to accommodate a 76mm down pipe and is made from 4.5mm (3/16") 6061 aluminum and then Type II clear anodized. The spacers are only if you need them. I have an Evo 9 RS with a 76mm WORKS down pipe and I have to run the WORKS Croxx Plate II because the down pipe is wider. We did try to fit a Croxx Plate I on it (that was a no, go) and I did not use any spacers for the Croxx Plate II, so yes.
